Activity Forums Apple Final Cut Pro Legacy Editing with 10bit uncompressed 4:2:2 from Hyperdeck Shuttle and SONY F3 Slog
  • Editing with 10bit uncompressed 4:2:2 from Hyperdeck Shuttle and SONY F3 Slog
    Posted by Peter Fuhrman on April 9, 2012 at 7:18 pm
    Hello everyone,
    I’m a new owner of the Hyperdeck Shuttle 2. I am using it with my SONY F3 and the Slog option for 4:2:2 10bit uncompressed recording.
    So far my Final Cut Pro sequence DOES NOT like to play back the footage without dropped frames. Help?
    Peter
    Michael Gissing replied 14 years, 4 months ago 3 Members · 2 Replies
  • Neil Patience
    April 9, 2012 at 7:38 pm
    You need very fast hard drives to play back 10 bit uncompressed video.
    Standard def has a bitrate of about 270 Mbs and HD is way higher – over 1Gbs I think.
    So that’s why you are struggling to play it back – unless you have a fast fibre or esata raid it’s going to stall.
    That’s why ProRes is a good option. HD ProRes is less bandwidth than SD 10 bit Uncompressed.
    best wishes
    Neil
    http://www.patience.tv
  • Michael Gissing
    April 9, 2012 at 10:53 pm
    The shuttle also uses DNxHD codec for compressed HD. DNxHD is a great codec like ProRes 422 and has similar compression. DNxHD can be used with Final Cut Pro if you download the free codec from AVID.
    I am working on a project shot F3 SLOG to DNxHD on a Sound Devices PIX240 and I will be grading in da Vinci and finalising in Final Cut 7. Depending on frame rate DNxHD and ProRes422 can run off a Firewire 800 drive but esata or an internal RAID would be more reliable for dropped frames.
