Activity › Forums › Adobe Audition › Editing Waveform so it does NOT pass horizontal white lines?
  • Editing Waveform so it does NOT pass horizontal white lines?
    Posted by Joey Kane on September 30, 2009 at 5:29 pm
    Hi I need some help here… I have the same track from two different sources. Both are in uncompressed WAV but one has used some processing that does not let it go past the horizontal white lines in Edit View… Here is what I mean:
    NON-PROCESSED WAVE FORM:
    https://i37.tinypic.com/20ihun9.jpg
    PROCESSED TO NOT PASS WHITE LINES ON BOTTOM/TOP OF WAVEFORM:
    https://i35.tinypic.com/2rmb2tv.jpg
    What effect (and settings) should I use to get this type of limiting/normalizing that is done to the second waveform?
    Thanks.
    Scott Smitelli replied 17 years ago 2 Members · 1 Reply
  • Scott Smitelli
    October 5, 2009 at 1:03 am
    It looks like the second wave is using the Hard Limiting effect, with the max amplitude set to -1 dB. Personally, I would use Normalize instead (it doesn’t distort the wave at all, it merely decreases the overall amplitude) but that’s not what your second image is showing.
