Activity Forums DaVinci Resolve Editing w/Davinci & FX-6 footage HD
  • Editing w/Davinci & FX-6 footage HD
    Posted by David Kaltenbach on October 27, 2021 at 8:37 pm
    I am ready to start editing 4 months of raw footage that I shot on the Sony FX-6 (Advanced XAVC Codec). I am still not happy with DaVinci Resolve 17.4 It is not handling my HD footage properly. Need HELP. It still is stuttering, I lose audio, it pauses… never had this issue with FC7 after 20 years. I edit on an iMAC 5k, 27″ 2017, processor 4.2 GHZ Intel core 17, memory 40GB 2400MHz DDR4, version 10.14.6., Graphics Radeon Pro 58 8Gb
    Question: if I jack up the memory to 64G, will it change? Or is this whole thing confused inside Resolve where I may need to change settings. HELP me mucho raw HD footage from the FX-6 that I need to blow thru with Black Magic’s Speed Editor. Thank you.
    I can’t imagine cutting 4k with this unresolved issue.
    David Kaltenbach replied 4 years, 10 months ago 2 Members · 5 Replies
  • Pete Anderson
    October 27, 2021 at 9:00 pm
    Have you tried lowering the time line resolution David?
  • Pete Anderson
    October 27, 2021 at 9:46 pm
    Just read that free version doesn’t support 10bit xavc on Macs, not sure if that’s still a thing though.
  • David Kaltenbach
    October 27, 2021 at 10:07 pm
    Thank you Pete. I have the purchased Davinci. But I will check that out thru Black Magic about the 10 bit. In regards to your prior message. I cannot find the where I have control over the timeline res. Appreciate your help.
  • Pete Anderson
    October 27, 2021 at 10:53 pm
    If you open settings, little cog in bottom right corner the time line resolution setting should be there at the top of page, try using a lower resolution and see if that helps to start off with. Doesn’t affect your final render.
  • David Kaltenbach
    October 29, 2021 at 9:41 am
    Thank you Pete I’ll try that on this lovely day of rain and great editing
