Activity Forums Apple Final Cut Pro Legacy editing w/ 720×480 footage in a 16:9 sequence
  • editing w/ 720×480 footage in a 16:9 sequence
    Posted by Elias Gwinn on November 19, 2012 at 7:39 am
    I know that variations of this question has been asked a million times, but I haven’t seen anyone ask specifically about what I want to do.
    I want to edit 720×480 footage on a 16:9 canvas (w/o stretching or scaling…keeping the black bars on the side).
    I was able to achieve this by choosing ‘Custom 853×480’ in the sequence settings menu, but the problem is this:
    The raw footage constantly needed to be re-rendered, whereas the raw footage did not need to be rendered when the sequence was set (automatically) to the native format (720×480 NTSC).
    The reason I need to edit on a 16:9 canvas is because those black/blank vertical areas on the sides will occasionally be used within the sequence (solid color, scaled footage, etc).
    The deliverable will be 16:9, with the vertical areas on the sides black/blank throughout the majority, but not all of it.
    Just to re-iterate my question: what sequence setting can I use to edit 720×480 footage on a 16:9 canvas without needing to constantly re-render the raw 720×480 footage?
    Elias Gwinn replied 13 years, 9 months ago 2 Members · 3 Replies
  • Rafael Amador
    November 19, 2012 at 3:34 pm
    Make sure that in User Preferences > Editing tab you have checked “Always Scale clips to Sequence Size”.
    Then open a DV Anamorphic sequence and drop the DV 4×3 stuff on it.
    rafael
    http://www.nagavideo.com
  • Elias Gwinn
    November 19, 2012 at 4:09 pm
    This seems to work!
    BUT… I did a test cut, and QT export, and a compress to 853×480 (using MPEG Streamclip) The result is the video is stretched up a little bit, and some information is cut off from the top (see the attached image).
    Any suggestions for proper exporting w/ this format?
  • Elias Gwinn
    November 20, 2012 at 1:09 am
    Oops, just realized the image wasn’t included in that last thread. Here it is:
