Activity › Forums › Apple Final Cut Pro Legacy › Editing via Remote Desktop?
  • Editing via Remote Desktop?
    Posted by Brad Bussé on June 19, 2008 at 9:11 pm
    My company has a telework program that I can apply for to work from home 1 day a week. Is it possible to use Remote Desktop to edit from home, or is it too slow to transmit what’s on the screen – and does it allow access to audio (either from the Mac or my Kona 3 card)?
    Also, do I need to have the exact same monitor setup, or is it possible to use a couple of full frame 20″ monitors at home, while my monitors at work are widescreen 24″?
    John Fishback
    replied 18 years, 3 months ago
    8 Members · 10 Replies
  • 10 Replies
  • Mark Maness
    June 19, 2008 at 9:25 pm
    That’s what I thought, too…
    I remember hear the networks using stuff like T1 lines for this kind of thing but that’s WAY too expensive for the average joe.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Brad Bussé
    June 19, 2008 at 9:47 pm
    Damn. Thanks for the input.
    I’ve been hearing about fiber optic connections to the net that are now available to consumers, does anyone have this or know what the monthly cost is? I wonder if I had fiber optics if the bandwidth would be preserved from home to work. If so, then I could have my IT crew possibly dedicate my connection directly to my Mac via fiber optics -> fibre channel. Any thoughts as to the viability of this?
  • Winston A. cely
    June 19, 2008 at 9:49 pm
    [Wayne Carey] “I remember hear the networks using stuff like T1 lines for this kind of thing but that’s WAY too expensive for the average joe.”
    If only I could bring in that kinda money…..
    Winston A. Cely
    Editor/Owner | Della St. Media, LLC
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Mac Pro 3GHz Dual-Core Intel Xeon
    4 GB RAM | Final Cut Studio 5.1.4 | Aja Kona LHe
  • Zane Barker
    June 19, 2008 at 9:55 pm
    You will NOT get real time video, the video will stutter a LOT and there is NO audio.
    I would look into a MaacBook Pro to take back and forth.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Brad Bussé
    June 19, 2008 at 10:11 pm
    I have a MacBook Pro, but it doesn’t have A/V drives. So if I’m mainly working with HD ProRes in FCS, Shake, and AE, would I be able to be productive working from the MBP using a FW800 mini RAID from Medea or LaCie, or would I more likely need eSATA? And is there a card for the MacBook Pro (core2 duo) that has eSATA ports? Thanks.
  • Colin Mcquillan
    June 19, 2008 at 10:26 pm
    There are a few express 32 slot eSata cards on teh market out there.
    I do a lot of field editing/hotel room editing on a macbook pro with FW800 drives.
    Its not bad at all on simple timelines, but if you are like myself and usually work on a fast mac pro station, you will notice a big perfomance difference when you add an effect or two, especially in AE/Motion (sorry, don’t use shake.) To speed up productivity of more complex timelines in FCP, AE, or Motion, I turn down the playback resolution to half or a third and that really speeds up responsiveness and playback performance.
    Colin McQuillan
    Van. B.C.
    ;-P
  • Chris Borjis
    June 19, 2008 at 10:51 pm
    Even a T1 would be inadequate for a task like that.
    I used to network manage a NW region of a computer maker and we used Citrix and Terminal server. It was barely adequate just for a remote desktop on a standard T1 line.
    you “might” be able to do this over FIOS (FIBER), point to point.
  • Sean Oneil
    June 20, 2008 at 12:12 am
    Verizon FIOS is what you would need. It’s only available in a few markets. Even then you are pushing it. Upstream is still only 15mbps. You could move to a European country where everyone is connected via gigabit ethernet. We’re very, very behind here in the US.
    Sean
  • Brad Bussé
    June 20, 2008 at 12:52 am
    I blame youtube….
    Thanks for all of the input everyone. One more question; is there a way to sync playback of Quicktime files between 2 remote computers? I’m thinking if I use an external drive and work on the MacBook Pro, I’d still need a way to preview Quicktime renders with a client via phone with both parties able to view the same movie at the same time in sync.
  • John Fishback
    June 20, 2008 at 1:07 am
    An associate uses Slingbox so his client’s can review edits: https://www.slingmedia.com/go/slingbox
    Also, there’s https://www.syncvue.com/
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.4, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w 192 Digital, SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
