Activity Forums Apple Final Cut Pro Legacy Editing Varicam and HVX 200 with HDV clips
  • Editing Varicam and HVX 200 with HDV clips
    Posted by Donpdm on December 27, 2006 at 8:22 pm
    My company is contracted to produce a show for Speed TV called Epic Ride. So far it’s Epic Hell but we’ll go on. I shot all the first segment stuff with 3 varicams 24p to tape. I have some b-roll that was shot 24p on HVX 200 but dumped to tape via 1200a deck. This segment lives within iteself as we go to break at it’s conclusion. The Epic Rides which are motorcycle trips are shot on 3 HVX 200 24pn 720. I have a few POV b-roll clips to edit in that are shot 1080I HDV.
    Here are the questions.
    Edit gear FCP 5plus
    dual core most powerful you can get 4 gigs of Ram
    1 aj 130 dc panasonic deck
    Kona HD LHe with breakout box
    1. How ahould I handle the timeline as I want a 720 HD master of each show I deliver SD digibeta??
    2. Can I have go with 24p timeline and convert these b-roll clips to this? and how?
    3. How to handle HDV 1080i in this senerio
    4. When importing which Kona setting would be best and use least space?
    I just need to get this work flow down as were in hell mode to finish. Any help here appreciated.
    PS Gary Adcock I met you at advanced varicam Big Vision and John Scharaf is helping me said your the guy.
    Need answers soon!
    Don
    Pipeline Digital Media
    Shane Ross replied 19 years, 9 months ago 4 Members · 6 Replies
  • Shane Ross
    December 27, 2006 at 8:50 pm
    [DONPDM] “1. How ahould I handle the timeline as I want a 720 HD master of each show I deliver SD digibeta??”
    Since DVCPRO HD 720p is Non-Drop frame, and you will need to deliver a drop frame Digibeta, you need to adjust your timing to match the DROP FRAME master. I go into a bit of detail on how I did it here:
    https://lfhd.blogspot.com/2006/09/online-workflow-overview.html
    But I output to HDCAM, and then downconverted. You will be outputting to digibeta using your card. The Kona LH can downconvert on the fly, but you will still need to adjust the timing on your timeline.
    [DONPDM] “3. How to handle HDV 1080i in this senerio”
    Get an HDV deck and capture it thru the Kona into the DVCPRO HD codec, 720p24. Then it will match perfectly.
    720p24 24PN (HVX setting) at 23.98 is the setting that uses the less space and looks great. Matches the Varicam 24p (if it was shot 720p24 and not 720p60).
    Shane
    FCP Preferences set to UNCONTROLLED ADVICE
    Littlefrog Post
    http://www.lfhd.net
  • Mark Maness
    December 27, 2006 at 10:46 pm
    [Shane Ross] “Since DVCPRO HD 720p is Non-Drop frame, and you will need to deliver a drop frame Digibeta, you need to adjust your timing to match the DROP FRAME master. I go into a bit of detail on how I did it here:
    ” target=”_blank”>https://lfhd.blogspot.com/2006/09/online-workflow-overview.html”
    Ok… I read it and it sounds plauseable…. BUT how do you convert your footage that is drop frame into non-drop frame? FCP will not let you drop a clip with drop frame timecode on a non-drop timeline. I am still missing this part. This has been an issue that I have dealt with. My only solution was to batch recompress all of the footage into DVCProHD 720 24p. I have only done this ONCE so if its wrong…. forgive me. I’m still learning this HD thing.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Shane Ross
    December 27, 2006 at 11:10 pm
    [Wayne Carey] “BUT how do you convert your footage that is drop frame into non-drop frame?”
    You don’t. You don’t need to. All drop and non-drop refer to is the TIMECODE….the numbers. The footage runs at 29.97 or 23.98 no matter what code you have. If you drop non-drop footage into a drop frame timeline, nothing happens. All it is is timing. Non-drop code assigns sequential numbers to each frame, and drop frame drops occasional numbers so that timing is precise with real time.
    So, my DVCPRO HD timeline would ONLY ALLOW for non-drop code. It wouldn’t give me a drop frame timeline option, so I couldn’t get my show to exact time. So what I did was lay slug onto a 29.97 drop frame timeline until I got the exact timing I needed (the network wanted the digibeta to be to time, the HD master didn’t need to match that timing). Then I copied the slug into a non-drop timline until I figured out what time I needed to get my show to on a non-drop timelne so that when I output it to digibeta, it was properly timed.
    Now, I didn’t do a direct output, I had the master downconverted at a dub house. I don’t know about outputting 720p24 to digibeta and what it will do. If I had a machine I’d test it, but they are spendy, even to rent…just to test.
    [Wayne Carey] “FCP will not let you drop a clip with drop frame timecode on a non-drop timeline. “
    Sure it will. I do it all the time. Every edit system allows this. Again, they are just numbers, not any actual difference in the speed of the footage.
    I am STILL learning this HD thing…
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Gary Adcock
    December 28, 2006 at 3:07 pm
    [Shane Ross] “So, my DVCPRO HD timeline would ONLY ALLOW for non-drop code. It wouldn’t give me a drop frame timeline option, so I couldn’t get my show to exact time.”
    Shane
    this is only true for 24 fps content and has nothing to do with the DVCPROHD compression- HDCAM content at 24 is also non drop.
    Video content at 60 fields or 60 frames can be set for either.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Gary Adcock
    December 28, 2006 at 3:14 pm
    the kona card will lay off to the beta Directly, but note that you may have some TC issues As shane has said there are some DF/ NDF issues- I nest my final rendered 24p file in a new 59.94 seq and adjust the timing.
    depends on how much you have, The 1200 deck does have the ability to cross convert but your content will be interlaced rather than progressive. IF you only have a little bit your OK. if there is a lot it will be tougher.
    [DONPDM] “4. When importing which Kona setting would be best and use least space?”
    Stick to DVCPROHD 720p24 . it will simplify your issues down stream.
    thanks for the kind words also.
    gary adcock
    Studio37
  • Shane Ross
    December 28, 2006 at 4:29 pm
    [gary adcock] “this is only true for 24 fps content and has nothing to do with the DVCPROHD compression- HDCAM content at 24 is also non drop.”
    I know. Since I was working with 23.98 footage in a 23.98 timeline…I had a NDF timeline only. DVCPRO HD 720p60 is drop frame.
    Shane
    Littlefrog Post
    http://www.lfhd.net
