Activity › Forums › Panasonic Cameras › Editing using HPX500… more test results
  • Editing using HPX500… more test results
    Posted by Bob Woodhead on January 25, 2008 at 2:31 am
    *Finally* got around to testing multiple formats for the “edit & playback from camera” concept. For those that haven’t heard, you can edit using clips on the 500 via USB and FCP. Then “push” the edit back to a card in the camera when done.
    Great results…. DV25, DV50, DVCProHD 720 24p, DVCProHD 720 30p, and, yes, DVCProHD 1080i60. Tested using 30 second edit sequences, with effects & 3 channels audio output. This is no replacement for a fast RAID array with SCSI or FW800 interface, but for basic editing, it should be fine. Note the obvious limitations on space…. you can only use cards **in** the camera (no swapping), and space for the final edit output must also be available (though you could create a card image on the laptop, re-format one of the cards, and then copy the image to the card).
    But thinking of ultra-fast run n’ gun, followed by the fastest edit POSSIBLE ANYWHERE, then SDI-HD/SD output, well….. WOW!
    Oh yeah, Raylight is mandatory for this exercise.
    “Constituo, ergo sum”
    Bob Woodhead / Atlanta
    http://www.CoolNewMedia.net
    Quantel-Avid-FCP-3D-Crayola
    Panasonic HPX500
    Phil Jones replied 18 years, 8 months ago 3 Members · 5 Replies
  • Nate Stephens
    January 25, 2008 at 2:46 am
    Bob, Your doing all this via firewire and a 15″ MacBook Pro. No extra Hard drives?
    This is great news.. Location > shoot > edit > deliver > Pay me Now… I love it … Oh you want her lips “just a shade redder” no problem but that’s extra…
    You have a Fuji Lens on your 500 ? does it have the 2x extender? is the 2x worth it?
    Still prefer the fuji over Cannon?
  • Bob Woodhead
    January 25, 2008 at 3:07 am
    USB 2 & 17″ MBP, FCP & Raylight. Only drive is in MBP.
    Fuji w/ 2X. 2X is useless…. unless you need it. 😉
  • Phil Jones
    January 29, 2008 at 5:36 pm
    I tried to reload a clip into a card in the camera and could not get it to work.
    The Raylight instructions were a bit thin and as far as I could tell you could only reload a maximum of one card (no spanning) and no multiple clips per card. I would love you to outline a detailed method of how you uploaded your edit. Also do you have to make a .mov file of the finished sequence?
  • Bob Woodhead
    January 30, 2008 at 2:13 pm
    Do your edit, make a QT output (it can be a reference file, doesn’t need to be complete w/ media).
    In Raylight, open the P2Maker tab & drop that file on the tab (or use Raylight’s instructions on how to use the “scan folder” for the source file).
    I haven’t tried the metadata import function yet… hasn’t been a concern for me.
    Have the destination card mounted (either directly or in the camera) & use the Destination section of Raylight to point to it. **IMPORTANT** if you have multiple cards mounted, they **MUST** have unique names (not NONAME – I use simply A, B, C, D) or the output will fail.
    Select the card size & hit Start.
    I’ve tested writing to cards with and without pre-existing clips on the destination card, success either way.
  • Phil Jones
    January 30, 2008 at 3:37 pm
    Bob,
    Thanks for taking the time to respond. I’ll give that a whirl.
    Regards
