Activity Forums Adobe Premiere Pro Editing unrendered cips
  • Editing unrendered cips
    Posted by Bruno Silva on August 1, 2008 at 6:39 pm
    Quick question. I’m editing a clip with 3 video tracks, none of which are rendered. Since they are not rendered I have tons of lag as i surf through the timeline makng cuts so its hard to get precision.
    I know its common, but is there a way to avoid this? If i render, it will take forever and once i make changes in the edit it will just need rendering again.
    Assistant Editor
    http://www.harringtontalents.com
    Ann Bens replied 18 years, 1 month ago 3 Members · 2 Replies
  • Vincent Rosati
    August 3, 2008 at 6:42 pm
    I guess you are looking for some system optimizing for editing. Maybe update your profile to include your system specs.
    Uninstall any software you don’t need from your OS.
    Run antivirus and anti-spyware.
    Are your clips in an editing format; Uncompressed, DV, HD, etc.
    MPEG and other compression methods can cause preview to be slow or choppy.
    An optimal setup is three drives:
    1 – OS, Apps, Project Files
    2 – Source Material
    3 – Preview Files
    Defragment all drives.
    Disable preview on DV hardware, in the Premiere project.
    Vince
  • Ann Bens
    August 3, 2008 at 7:24 pm
    You could set the playback quality to draft.
