Activity Forums VEGAS Pro Editing To BPM
  • Editing To BPM
    Posted by Clay Dempsey on May 27, 2008 at 6:20 pm
    I could have sworn that in Sony Vegas 7 I could edit with the timeline being set to BPM. Now I’m using 8 and I need to edit in betwee 122 and 126 BPM….was I wrong about this? Any suggestions would be appreciated.
    Clay
    John Rofrano replied 17 years, 12 months ago 2 Members · 1 Reply
  • John Rofrano
    May 27, 2008 at 6:42 pm
    Not sure what you were doing in 7 but 8 has everything that 7 had. There are several things that you can do to work in a particular BPM:
    1. You can change the timeline ruler to Measures & Beats
    2. Also, you can go into the Project Properties and on the Ruler tab you can set the Beats per minute for the project
    3. Finally, you can go into Options | Preferences | Audio and check Import audio at project tempo
    All of these will allow you to edit in the BPM that you choose. You might also be thinking about Sony ACID which has a much stronger affinity with BPM to the timeline, but Vegas 8 can do whatever Vegas 7 did in this regard.
    ~jr
    https://www.johnrofrano.com/
