Activity Forums Apple Final Cut Pro Legacy Editing timebase settings when capturing using advanced pulldown removal
  • Editing timebase settings when capturing using advanced pulldown removal
    Posted by Ben Baudhuin on September 28, 2005 at 6:23 pm
    I just needed to know what the correct sequence settings were for footage captured using the advanced pulldown removal setting in FCP I have some 24p footage and when I drop it in the sequence at 29.97 it comes up unrendered, and when I put it in at 24 the green bar comes up over it, I know there must be a setting for the advanced pulldown removal, so if anyone could tell me I’d really appreciate it. Thanks,
    Ben
    Ben Baudhuin replied 20 years, 12 months ago 3 Members · 3 Replies
  • Shane Ross
    September 28, 2005 at 9:19 pm
    You should be using a 23.98 timebase.
  • Jeremy Garchow
    September 29, 2005 at 12:21 am
    You CAPTURE settings should still be 29.97 (since that is the frame rate that the tape is running). There’s also a tick box to remove advanced pulldown from dv25/dv50 sources. Your SEQUENCE settings should be at 23.98 and you should need not have to render.
    Sorry about the caps I just wanted to be clear.
    Hope this helps.
    Jeremy
  • Ben Baudhuin
    September 29, 2005 at 2:16 pm
    thanks for the input, I appreciate it
