Activity › Forums › Adobe Premiere Pro › Editing stills in Premiere Pro
  • Editing stills in Premiere Pro
    Posted by Pete Fair on September 30, 2006 at 2:12 am
    I’m editing UNCOMPRESSED video for a digibeta output. I need to add STILLS and I wonder the kind of resolution and NTSC ratio I should use in my Photoshop files for best results. I would appreciate any advice in this regard.
    Thanking you all in advance, Pete
    Mike Velte replied 20 years ago 3 Members · 6 Replies
  • Vince Becquiot
    September 30, 2006 at 3:24 am
    You are are working in Square Pixels, you should export at 640×480 (Don’t forget about the safety margins)
    Vince
  • Pete Fair
    September 30, 2006 at 5:05 am
    Dear Vincent,
    Thank you very much for your post. I tried the aspect ratio and it’s good! However the picture quality it is rather poor. At 640 x 480 the image magnification does not hold well. I would like to increase the picture quality since the final product will be shown in a large screen.
    I am using images originally shot in 35mm slide film and scanned at 2820 (pixels per inch) I would appreciate your feedback regarding the latter. Best, Pete.
  • Mike Velte
    September 30, 2006 at 11:18 am
    If you plan on pan and scan for the stills reduce image size in Photoshop to about 1200 x 900 using Bicubic Sharper. In Premiere, deselect “Default scale to frame size” in Preferences>General.
  • Pete Fair
    October 1, 2006 at 2:34 am
    Dear Mike,
    Thank you for your kind reply, it indeed helps me a lot. On the other hand, when a mentioned that the film will be shown on a big screen a meant: a THEATER screen (film festival) Therefore, I yet wonder whether the resolution you recommended will be OK (?) and match the rest of the footage –all regular 16mm film and transfered to Digibeta. Also, you are right: all my stills have a slow zoom-in. In addition to it, could you please briefly explain what deselecting to “Default scale to frame size” does to the pictures?
    With best regards, Pete
  • Vince Becquiot
    October 1, 2006 at 3:39 am
    If your end result is Digibeta, then your resolution will still be standard video (720 x 480).
    If you zoom in at 200%, just double the resolution of standard video for your picture export. In square pixels that would translate to 1280 x 960. Or why not just work with the raw pictures at their original resolution ?
    Unless it ends up slowing down your machine to a crawl…
    Vince
  • Mike Velte
    October 1, 2006 at 11:31 am
    When Premiere scales images automatically, it creates a smaller version of each still in media cache that does not hold up well to motion.
