Activity › Forums › Maxon Cinema 4D › Editing Splines
  • Editing Splines
    Posted by Israel Unger on October 18, 2005 at 7:48 pm
    So, I’m not really a Cinema 4D (or any 3D) person, but I’ve inherited a revision to a Cinema 4D file that I don’t know how to execute. As the file stands a sweep object animates along a spline. The shape it draws is a dollar sign, but now has to be changed to a Euro. Of course, I can select the individual points and try and reshape the object, but doing this to form something as exact as a symbol (with probably nowhere the same number of points as the original) – hand reshaping doesn’t seem the way to go about this. I’ve imported (merged) illustrator vectors before. Is there a way I can use an illustrator file to replace an existing spline in the project.
    Any help would be most appreciated. Oh, if it matters, I’m using C4D R8
    Israel Unger replied 20 years, 11 months ago 2 Members · 2 Replies
  • Chris Smith
    October 19, 2005 at 5:09 am
    either use the text tool in C4d to create a euro symbol or generate it in AI. If in AI, create outlines, save as an eps version 8. Import into C4D. Your dollar sign should be a spline inside a sweep nurbs. Pull out the dolloar sign and replace it with it with the eps.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Israel Unger
    October 21, 2005 at 7:40 pm
    Thanks. Worked perfect
