Activity › Forums › Canon Cameras › Editing Software for HF100
Posted by Paul Melonakos on April 20, 2008 at 8:43 pmI am having a hard time finding editing software for my new Vixia HF100. I want software that captures, edits, and burns the AVCHD format on a standard DVD. Any suggestions?
Kirk Hopkins replied 18 years ago 4 Members · 11 Replies -
Craig Cooper
May 30, 2008 at 9:46 amHi Paul,
I see it’s been more than a month since you posted. Did you come right or are you still looking for a solution?
Cheers Craig
Peace Talks Hamper War in Middle East
Paul Melonakos
May 30, 2008 at 1:11 pmI bought Corel Video Studio 11.5, and it works great. Thanks for asking.
Craig Cooper
May 30, 2008 at 7:36 pmThe reason I asked is I bought the Canon HF10 which also captures in AVCHD which is great but you cannot put AVCHD straight onto a DVD because 95% of DVD players can only read MPEG2 encoded movies. Which means whatever you render will finaly end up being encoded MPEG2.
I experimented a bit using Sony Vegas 8 Pro and got really crap DVD movies. I was doing it wrong. The correct method in SV8 is to start new project with settings that you captured in, eg. 1920×1080. Import your clips into the project as normal and edit as normal. Then render your movie as AVCHD with audio so will will have 1 AVCHD which will have a file MT2S extention. Be warned this file will be huge. Then open DVDA 4.5 and import your MT2S file into your project. Select Burn DVD. You now will have the high def in DVD format which has been been rendered in MPEG2 but beautifully.
Try it and let me know.
Cheers Craig
Paul Melonakos
May 30, 2008 at 11:39 pmVideo Studio 11.5 allows you to burn AVCHD unto DVDs and then it plays beautifully on our Sony Blu-ray player. The video is so clear that it equals the video we see when we connect the camcorder directly to our HD TV with an HDMI cable. The whole process of importing video, editing, and burning is almost as easy as with standard definition clips. Paul
Kirk Hopkins
July 30, 2008 at 1:34 pmDoes Sony Vegas Movie Studio 8 allow you to use .m2ts files from a Canon Vixia HF100?
I haven’t tried Vegas yet, I’m hoping Movie Studio will work. $100 vs $500.
I’m using a MacBook Pro so I can use Windows via Boot Camp or the Mac OS. I was hoping to switch to an Apple product but the Apple editors (iMovie 08, Final Cut Express, & Final Cut Pro 6) convert the files (which takes a while) to Quicktime .mov and other formats. The files become huge. That’s crazy. I would switch to one of the Final Cut’s if it weren’t for that.
The Pixela ImageMixer software that comes with the camcorder is NOT something I recommend using. It’s just not at par with other editors on the market these days.
Kirk Hopkins
July 30, 2008 at 7:57 pmAVCHD (and probably HD in general) appears to be half-cooked. I downloaded a trial version of Sony Movie Studio Platinum Version 8 and it worked with my Canon Vixia HF100 files! Then I purchased the software. Next I got a reply from Sony saying that it wouldn’t work (not even in Vegas Pro). Hmmmm. Seems to me that it worked.
Looks like I can’t output in 1080p though. 🙁
I can generate a 720p file which has a .m2t extension. Renaming it to .mpg allows me to play the generated file.
I’d say if you wanna do HD editing, you’ll find out you’re on the bleeding edge.
Paul Melonakos
August 1, 2008 at 3:54 pmI have been using Corel Video Studio 11.5 to edit HD with my Canon HF-100. It edits AVCHD and burns AVCHD on a standard DVD. I then play it on my Bluray player. The video is stunning. Paul
Andrey Baranovsky
August 11, 2008 at 8:21 amHi,
I would like to edit my HF100 footage (glue clips together, add transitions, etc..
and render the result into exactly the same format that the camera shot in.I want to do it in such a way, that the UNEDITED VIDEO WOULDN’T BE RECOMPRESSED!
The output should be playable by the camera….Any idea which editing software can help me with this?
Andrey. -
Kirk Hopkins
August 11, 2008 at 1:25 pmI believe that you can use the software the came if with Canon HF100 to edit, add transitions, and then dump the edited file back to the camera. The software however is not very user friendly. Don’t expect to do much else with it. Other than that software, I think you’re going to be out of luck. I haven’t found anything yet that allows me to save edited footage back to the camcorder unless you edit with ImageMixer. 🙁
After I attempted to use the ImageMixer software for editing I found very limited; I quickly went back to my old friend, Sony Vegas Movie Studio version 8. As you can see from previous posts, the Sony software didn’t do exactly what I wanted (1080p output).
Sony Vegas Movie Studio Platinum version 9 just came out (8-1-2008). Here’s the family comparison:
https://www.sonycreativesoftware.com/moviestudiope/compareI’ve used Sony’s software since December of 2004 and love it. It’s very intuitive. Version 9 allows you to save in 1080p in a couple different formats. Here are the 2 options that look the most promising so far:
WMV in 1080-30P with 5.1 Surround sound
MPG in 1080-24P (MPEG 2)A short test film that I created looks wonderful. I haven’t dumped any edited footage out to the web yet, but plan to have something soon.
My plan is to buy a 500GB or 1TB external hard drive (for $100-$180) to store my movies on until Blu-ray discs drop down in price. Who knows, maybe we’ll just be playing our movies from solid state drives some day. Oh wait, that’s what the Canon HF100 does. I’m gonna need more than 8GB though. I’ve seen someone say that “AVCHD is more of a suggestion than a standard” and believe that statement to be true. Because of that factor I think you’ll be hard-pressed to do what you’re looking for (save the edited movie back out to the camcorder). I think there are good alternatives though (WMV and MPG).
In conclusion, I’m very happy with the Canon HF100 and Sony Vegas Movie Studio Platinum version 9 and plan to continue to use this duo to create vacation videos, short films, & other projects for the foreseeable future…Kirk.
Andrey Baranovsky
August 11, 2008 at 1:44 pmHi,
Thanks for the answer…but:
The transition back to the camcorder – is of secondary importance.
But fast rendering – namelly keeping unedited video as-is – is important.I would settle for achieving at least this goal….
I have sone vegas pro 8 installed. Could you please recommend me some project + camera settings, that will prevent Sony Vegas from re-rendering?Thanks,
Andrey.
