Activity Forums Apple Final Cut Pro Legacy Editing SnapzPro footage in Final Cut
  • Editing SnapzPro footage in Final Cut
    Posted by David Lesondak on August 7, 2010 at 2:11 pm
    Okay, I’ve seen similar posts, but here’s the deali-o
    I have an idea for a killer music video using footage from existing footage I have stored in iTunes (you see stuff like this all the time on YouTube).
    When I import the footage into Final Cut I have to render the clips and then re-render them every single time I alter any rendered clip.
    Also the rendering process takes an inordinately long time (I’ve got a new 27″ iMac, so its not my machine).
    I looked at the SnapzPro prefs and reset the frame rate to 30, thinking that would fix it but it really hasn’t.
    Can anyone help, or recommend a different program for capturing, or both? I really want to get this out of my head.
    David
    Lynette Gilbert replied 16 years, 1 month ago 5 Members · 6 Replies
  • John Fishback
    August 7, 2010 at 6:30 pm
    Use Compressor to first convert your footage to ProRes. Then your edits will go smoothly without all the re-rendering.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jerry Hofmann
    August 7, 2010 at 10:22 pm
    Google iShowU.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Craig Alan
    August 8, 2010 at 2:58 am
    Jerry,
    Looking for a good screen capture app. Downloaded ISHOWU. Looks like a great feature set. I get most of the options. But what do I set in order to frame the capture the way I want. I see a back frame, but I can’t grab it with hand to move it or grab corners to resize it. I am also getting a message that says if i want to get rid of logo or water mark to click on it and press delete. But I don’t see it on the screen. What settings are messed up? As soon I click anywhere I’m switched to the app beneath it.
    OSX 10.5.7; MAC Book PRO (EARLY 2008); Camcorders: Sony Z7U, Canon HV30, Sony vx2000/PD170, Canon xl2; Pana, Sony, and Canon consumer cams; FCP certified; write professionally for a variety of media; teach video production in L.A.
  • Jerry Hofmann
    August 8, 2010 at 1:18 pm
    I’d suggest you read the Manual…. it’s all explained there. It’s short too!
    Jerry
  • Craig Alan
    August 8, 2010 at 3:36 pm
    Tried that but nothing quite matches what’s on-screen. I think I might have a preferences issue or something. I’ll try a fresh download and try again.
  • Lynette Gilbert
    August 9, 2010 at 1:57 pm
    I use SnapzPro all the time for screen capture, but I’ve never had a problem. I use it for videos that demo website navigation, and that requires animation (zooming, panning, etc.) so I work with it in Motion. I don’t think I’ve ever worked with SnapzPro files directly in FCP.
    Of course, you have to render the Motion file after you import it into FCP, but it goes really quickly.
    What kind of file are you saving it as?
