Activity Forums Apple Final Cut Pro Legacy Editing SD w/o capture card
  • Editing SD w/o capture card
    Posted by Loren Hillebrand on July 10, 2006 at 8:09 pm
    I have a possible SD project, but have no capture card or SD deck. Can I have the footage captured to a RAID on someone else’s system, install those drives in my RAID, then edit on my own computer, without a Kona or Black Magic card?. I would then take the project file and drives back to have them output to tape on the other system. Do I need the card in my computer to edit SD, or just to capture and output? Thanks.
    G5 2.3 dual core/4 gigs ram
    Shane Ross replied 20 years, 2 months ago 3 Members · 4 Replies
  • Shane Ross
    July 10, 2006 at 8:18 pm
    As long as you have the codecs, you will be fine.
    I have done this more than once.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Walter Biscardi
    July 10, 2006 at 8:24 pm
    The only downside to editing without an SD capture card or an AJA Io is the inability to view your project on an external monitor. Without that, you will not be able to catch any interlacing issues with fonts or images, nor will you be able to color correct accurately for regular TV.
    Walter Biscardi, Jr.
  • Loren Hillebrand
    July 10, 2006 at 9:48 pm
    Thanks for the help. Another question –for a short program, could I use the second internal drive (250 gigs) as a media drive for a SD project, or do I need to have a RAID?
    G5 2.3 dual core/4 gigs ram/ 2 X 250 internal drives
  • Shane Ross
    July 10, 2006 at 9:55 pm
    Possibly 8-bit….possibly. You are really best going with at least SATA Raid for uncompressed work.
    Shane
    Alokut Productions
    http://www.lfhd.net
