Activity Forums Adobe Premiere Pro Editing SD of HD
  • Editing SD of HD
    Posted by Gerwin De keijzer on December 11, 2017 at 7:20 pm
    Hi there,
    We are a small non-profit broadcasting organisation inside a hospital.
    We maken promo-movies and instructional items.
    Our camera, a Sony PDW530, SD with XDCam disc creates stunning pictures.
    We sometimes get some external footage from a handycam or actioncam.
    As we all know, the pictures from these camera get better and better every generation.
    In our editing, we would like to combine both sources thus having to choose how to deal with the different formats.
    So, my question. Upscale our SD material to HD and edit? or downscale the HD content and create a SD sequence in PPro.
    Our audience more and more want DVD or BR. For BR we need higher quality. Can we achieve higher output using our SD and good upscaling?
    Regards,
    Gerwin
    Johnny Briggs replied 8 years, 4 months ago 8 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    December 11, 2017 at 8:04 pm
    Upscaling SD to HD…here is the list of best quality way of doing it to least quality way…
    1) Hardware upscale…TERRANEX from BlackMagic design.
    2) After Effects upscale.
    3) Premiere Pro upscale in the timeline.
    4) Transfer it to a VHS tape, have your dog chew on it, and then capture that as HDV, convert to H.264 five times.
    Don’t do #4.
    So the options you have already are After Effects and Premiere. They upscale decently, but your footage will still look like SD (softer) next to the HD footage, nothing you can do about that. But making it look better is the goal….
    Shane
    Little Frog Post
  • Gerwin De keijzer
    December 11, 2017 at 9:02 pm
    Haha, LOL for option 4.
    1) No option (yet)
    2) Ok, that might do the trick. I’ll try some footage
    3) Equals 2
    4) hehe
    Any plugins that might do the job quicker or better?
    Thanx for the suggestions so far.
  • Jeff Pulera
    December 11, 2017 at 9:36 pm
    If you will be delivering as SD (DVD), then perhaps keep the production workflow as SD. For instance, if you put SD clips into an HD sequence, they get upscaled (= soft). Now if you export to DVD (SD) you are taking the SD video that was upscaled (softened already) and then converting it from HD back to SD = not pretty compared to exporting SD straight to DVD. No sense upscaling unless you must deliver HD.
    If you DO need to deliver as HD, can you use 720p rather than 1080p? Even if the “other” sources are 1080p, maybe downscale those to 720p, then the SD won’t have to be blown up as far as it would require if editing as 1080. A compromise.
    Meaning make a 720p Sequence in Premiere, and mix the 1080p and SD clips in it, and export as 720p. The HD clips will still be HD and look great, and the upscaled SD clips won’t look as obvious as they would in a 1080p export.
    Jeff Pulera
    Safe Harbor Computers
  • Andy Patterson
    December 11, 2017 at 9:45 pm
    [Gerwin de keijzer] “So, my question. Upscale our SD material to HD and edit? or downscale the HD content and create a SD sequence in PPro.”
    It is personal choice. Is there more SD or HD content? Can you create two movies/videos? One SD and the other HD? You don’t have to enlarge SD to fit the full screen of HD. You might be able to place motion graphics in the background to create a boarder and leave the SD scaled at 100% or upscale to 120% to 150% if needed. It will be very very important for you to see you composition on a broadcast monitor as opposed to the computer screen if you plan on outputting to DVD or BD. You also might be able to get away with placing two SD video clips side by side to help fill up the HD screen. There are a lot of options. It sounds like there might be some trial and error involved.
    [Gerwin de keijzer] “Our audience more and more want DVD or BR. For BR we need higher quality. Can we achieve higher output using our SD and good upscaling?”
    In that case I highly suggest you purchase an Intensity Shuttle by Blackmagic Design because you really need to see the composition on broadcast compliant hardware as opposed to your computer screen. It will be money well spent as demonstrated in the video below.
    https://youtu.be/u_gOE67i-MI
  • Richard Martz
    December 11, 2017 at 10:00 pm
    As far as I know, DVD and BR discs are no longer supported by Adobe or Apple. Toast Titanium has some rudimentary authoring capability. Stay out of SD world because everything will ultimately be HD and SD will be abandoned as it already has in some places. If you can’t deliver HD your organization will go around you to get things done when quality counts (as in marketing and fund-raising efforts). Once you are seen as second-rate your days of employment are numbered. Sell that SD camera and get something in HD even if it is only a basic set up. If your employer won’t buy it, consider purchasing it yourself. You’ll need it anyway when you go freelance.
    Sincerely,
    Richard Martz
    MagicMartz Media, Inc.
    BrikPower Batteries
    Atlanta, GA
    FCP X
    Panasonic GH4 4K cameras with Cinema Lenses and XLR/SDI/TImecode units
    ADOBE CREATIVE SUITE CC
    Premiere Pro
    DaVinci Resolve 9.0
    MAC 12 core w 64GB memory
    After Effects
    PhotoShop
    Illustrator
    Sony HD Cameras
    24\’ Camera Crane with Motorhead
    8\’ jib arm
    20K watts of lighting
    Multitrack audio
    Teleprompters
    Grip Truck/trailer
    Location video monitoring
    Door and hood mounts
    Lots of other Fun Stuff!
  • Andy Patterson
    December 11, 2017 at 10:22 pm
    [Richard Martz] “As far as I know, DVD and BR discs are no longer supported by Adobe or Apple.”
    I think you can still download Premiere Pro 6. Encore comes along for the ride and works with Premiere Pro CC.
  • Shane Ross
    December 11, 2017 at 11:24 pm
    Red Giant has one…
    https://www.redgiant.com/products/instant-4k/
    It’s OK…doesn’t match what I get with Terranex, and is comparable to After Effects.
    Shane
    Little Frog Post
  • Chris Wright
    December 12, 2017 at 2:35 am
    after effects cc has ‘Detail Preserve Upscale’ which is comparable to instant 4k or anything with smart unsharp bicubic interpolation.
  • Tero Ahlfors
    December 12, 2017 at 6:58 am
    Encore still works. At least on Windows. You can get that by installing Premiere CS6.
  • Johnny Briggs
    April 20, 2018 at 1:52 pm
    Premiere Pro you can use the Detail-preserving Upscale effects in After Effects vua Dynamic Link is a great way to upscale SD footage to HD without losing too much quality.
    This short tutorial explains how you can do this:
    https://youtu.be/Urnt6XeP0FA
