Activity Forums Apple Final Cut Pro Legacy Editing SD (DV50 PAL) – would SSD disk(s) work?
  • Editing SD (DV50 PAL) – would SSD disk(s) work?
    Posted by Niklas Wikman on September 26, 2012 at 9:25 am
    Apart from the fact that SSD disk are not as big as conventional disks (I think you can buy 470 GB SSD, but they cost about $800) can I use SSD as video disk at all?
    We work with documentary and our number of simoultanous DV50 streams are perhaps not that many…
    Should I stick with mechanical disks?
    Rafael Amador replied 13 years, 11 months ago 2 Members · 3 Replies
  • Rafael Amador
    September 26, 2012 at 9:29 am
    Why not?
    An SSD is just faster tan a mechanical disks.
    rafael
    http://www.nagavideo.com
  • Niklas Wikman
    September 27, 2012 at 1:42 pm
    OK, so using an SSD disk (in a bus-powered 2,5″ enclosure over FW800) would work just fine for me, shooting DV50 ?
    Another question: would 5200 rpm be enough for DV50 and a few simoultaneous streams?
    From what I understand 5200 rpm generates less heat.
    If you are using bus-powered (FW800) enclosure, what brand/model do you use?
    I used macsales/OWC up until last year, when the enclosure started to fail on me, not showing the disk content. (The disk itself worked fine in an externa SATA-dock).
  • Rafael Amador
    September 27, 2012 at 4:47 pm
    Yes, should be fine to move a few DV50 threads in real time.
    You shold be able to check the read/write speed of the HD with the “AJA System Test”. Is included with any AJA drivers.
    rafael
