Activity › Forums › Apple Final Cut Pro Legacy › editing SD and HD in one project
  • editing SD and HD in one project
    Posted by King Law on November 6, 2011 at 7:19 am
    i have some SD footage from a client so they also wanted to add some interviews which i shot for them in HD question is, is it possible to edit together SD video clips and HD clips and put to DVD?
    Chris Tompkins replied 14 years, 10 months ago 2 Members · 1 Reply
  • Chris Tompkins
    November 6, 2011 at 11:33 am
    Yes.
    If you are going to SD DVD and no Future need for a Bluray/HD file then
    Edit in a SD sequence.
    Drop the SD file into a new sequence and let FCP match it.
    Then drop in the HD clips and resize/position as needed.
    Having the same frame rates will be wise as well.
    Chris Tompkins
    Video Atlanta LLC
