Activity › Forums › Adobe Premiere Pro › Editing Premieres multi Camera in After Effects (CS6)
  • Editing Premieres multi Camera in After Effects (CS6)
    Posted by Ty Yachaina on September 29, 2012 at 2:54 pm
    Hello All,
    I know this has been a problem with previous versions, i was not sure if they fixed it in CS6 or not but it appears to be flawed.
    When i bring an edited multicamera sequence from Premiere Pro into After Effects (Via Dynamic Link) the footage will go into the comp,
    however, the camera i have active at the time will not show, it always defaults to the top layer. So, its really not using multi-camera.
    Does anyone have this same issue, or know of a workaround? Is there a script or plugin i can use instead to bring multicamera edits into after effects? This is really throwing off my project.
    Ty Yachaina replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
