Activity Forums Adobe After Effects Editing premier pro sequence in After Effects
  • Editing premier pro sequence in After Effects
    Posted by Anthony Qureshi on March 19, 2017 at 4:47 pm
    I’ve imported a Premier Pro project into After Effects to finish editing. All of the cuts from Premier are shown in After Effects as pre- comps, so when I double click on the clip, it shows the original, entire clip rather than the cut section I need to edit. I want to add warp stablizer, so even when I turn off “collapse transformation” while its in pre-comp, it still gets stuck “analyzing”.
    Help?
    Anthony Qureshi replied 9 years, 5 months ago 1 Member · 1 Reply
  • Anthony Qureshi
    March 19, 2017 at 7:26 pm
    Ok thank you. So then I ask, can I apply the warp stabilizer to the clips in Premier, import the project to After Effects and individually work on each clip’s effects in the properties?
