Editing PAL footage with NTSC
Kinda confused here… your advice would be appreciated.
I have been given a PAL DVD (obviously 720×576, 25fps) and it has to be intercut with NTSC footage (720×486, 29.97fps). I’d like to do this in 10-bit uncompressed, although the final deliverable will be a DVD.
Is there a better way to do this than what I have done so far?
1. Use MPEGStreamclip to demux PAL DVD and create a 720×576 25fps QT Movie.
2. Bring into a NTSC 10-bit uncompressed timeline at 29.97fps
3. Use Nattress Concerter to convert to NTSC.This workflow works, of course, but some of the motion in the video is a bit funky… probably due to the 25fps to 29.97fps conversion.
Would my results improve by using Cinema Tools to change the frame rate?
Thanks in advance.
Bob O’Brien
