Activity Forums Apple Final Cut Pro Legacy Editing out a loud bang in interview audio
  • Editing out a loud bang in interview audio
    Posted by Nathan Golon on May 20, 2008 at 2:42 pm
    In the middle of an interview I have what sounds like a firecracker or gunshot. I tried to cut around the sound, but the subject is speaking during the noise so it doesn’t work. While I know there is a way to reduce this sound based on its frequency, I’m not sure what the steps are to do it. Could anyone help?
    Nathan
    Arnie Schlissel replied 18 years, 4 months ago 8 Members · 8 Replies
  • 8 Replies
  • Kevin Monahan
    May 20, 2008 at 4:19 pm
  • Del Holford
    May 20, 2008 at 5:04 pm
    While Kevin may be correct, you might try posting in Audio Professionals forum as they have more knowledge of filters and plug-ins that might help.
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
  • Ron Craig
    May 20, 2008 at 5:18 pm
    Do you have a transcript of the interview? Perhaps you can find a point at which the interviewee said the same word that was interrupted by the bang and then just replace the audio of that word. Hopefully you can find more than one instance of that word being spoken at another time because intonation, volume, etc. will determine whether other iterations of the same word will sound good enough as a replacement. But I have done this several times successfully..
  • Chris Poisson
    May 20, 2008 at 5:21 pm
    Since the bang is likely short, it may be possible to cut the same word(s) from somewhere else in the interview and patch it in. I have done this successfully a couple of times for other audio faults, but it should work with a bang, if you have them saying the same thing that is.
    Good luck!
    Have a wonderful day.
  • David Roth weiss
    May 20, 2008 at 5:29 pm
    I always find that supering a large caliber bullet hole to the forehead of the interviewee really helps to sell the sound and what was once an unfortunate mistake can now become a chance to heighten the impact of that dull talking head. Saves on b-roll too…
    On a more serious note, Soundtrack Pro, which hardly any of us actually use of course, has a tool for this. I have seen it demoed, but I haven’t used it. Essentially, it analizes the track and produces a color waveform, different from the standard waveform, that enables you to lasso just the specific frequencies of the offending sound and then allowing you remove them. It looked to be quite amazing. Check it out in the manual and ask about it over on the STP Forum.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Les Kaye
    May 20, 2008 at 5:43 pm
    To ditto David (sorry for the alliteration)… Apple demoed this exact scenario last week at the FCP World Tour. I tried it at home later that night as a test, and it looks like it actually does work.
    http://www.leskaye.net
  • Nathan Golon
    May 20, 2008 at 7:36 pm
    Thanks everyone.
  • Arnie Schlissel
    May 20, 2008 at 8:33 pm
    [David Roth Weiss] “I always find that supering a large caliber bullet hole to the forehead of the interviewee really helps to sell the sound and what was once an unfortunate mistake can now become a chance to heighten the impact of that dull talking head. Saves on b-roll too…”
    But to really sell it, you should then use Motion’s particle system to spray brains out the back of the interviewee’s head!
    Seriously, David, I’m glad I didn’t have a beverage in my hand while reading this, or I would have become a particle system!
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
