Activity Forums Apple Final Cut Pro Legacy Editing on Mac FCP 5, Encoding and Authoring on PC—–HELP PLEASE
  • Editing on Mac FCP 5, Encoding and Authoring on PC—–HELP PLEASE
    Posted by Zvi4343 on June 28, 2006 at 8:23 pm
    I am looking for validated and efficient ways to take
    media cut on FCP 5 and compress it on a PC. I prefer
    to encode using a PC as Compressor, although easy to
    navigate, runs like a sick dog on my PowerBook G4.
    Currently, I am exporting my sequence from FCP using
    QT Export w/the following settings:
    Frame Size 720×480 NTSC DV (3:2)
    Pixel Aspect Ratio NTSC-CCIR 601 / DV (720×480)
    Field Dominance: Lower
    29.97fps
    QT Video Settings/Compressor: DV/DVCPRO – NTSC
    (quality 100%)
    Audio 48k; 16bit; stereo mix
    File size and playback on Mac seem good at this point.
    I am then encoding using Autodesk Cleaner to make
    .mov, .wmv, and elementary files. This is where the
    breakdown occurs with these files. Autodesk Cleaner
    has no trouble doing the same encodes to files that
    originate on a PC when using AvidXpress.
    So the question is this…am I dealing with some sort
    of Mac/PC incompatibility? Or is it something else.
    Anyone have a solution or thoughts.
    Thanks in advance.
    Zvi4343 replied 20 years, 2 months ago 4 Members · 4 Replies
  • Todd Beabout
    June 28, 2006 at 8:32 pm
    Make sure you have a .mov extension at the end of the movie file. If you can play the file in QuickTime on your PC, Cleaner should be able to handle it.
    -Todd Beabout
    Vazda Studios
  • David Roth weiss
    June 28, 2006 at 9:45 pm
    Procoder accepts standard QT DV files right out of FCP, so its certainly not a MAC to PC issue. What version of QT are you running on your PC? If yo haven’t updated QT lately you might be getting incompatibility based on that alone. But, be certain that none of your apps on the PC rely on an older version of QT…
    DRW
  • David Fortin
    June 29, 2006 at 2:10 pm
    I did a whole bunch of compressions for the internet using Sorenson SQUEEZE on the PC at the end of last year. My QT files were 8bit uncompressed, but that shouldn’t make a difference. I had no problem working on the PC with the files I exported from FCP. In fact, I liked the outcome of the WMV files on the PC and Squeeze better than what I was getting from Flip4Mac.
    Good luck.
    David
    Dual 2.5 G5 {OS 10.4.5}
    4.5 GB RAM
    FCP 5.0.4
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    Media Cleaner Pro 6
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
  • Zvi4343
    June 30, 2006 at 6:35 pm
    Thanks for the responses. I’m still trying to get to the bottom of it. It’s not a file extension issue or a QT issue. Just may be one of “those” things. Have figured a work around for the time being.
    Export w/AvidXpress settings from FCP
    Import to AVID on PC
    Export uncompressed
    Encode
