Activity › Forums › Sony Cameras › Editing .mts files in Adobe CS 4 DON’T WORK
  • Editing .mts files in Adobe CS 4 DON’T WORK
    Posted by Darius Cornean on December 14, 2011 at 3:46 pm
    Hello
    I hope I will find hear an answer of my problem because I’m exhausted looking for a solution.
    I shoot using Sony NXCAM and recording on SD card (64GB)
    I try to capture video files in Adobe CS 4. The extension of them are .mts
    Doesn’t work
    Then I find solution on pro.sony.com. There it’s said that to capturing from camera using software Content Management Utility. I downlaod software from the site, i capture then I try to open .mts files in Adobe CS 4. I could see the image but the sound no. The sound sound like an abuzz.
    For me converting the files is not a solution because i have thousand.
    Please help me
    Thank you very much
    Clint Fleckenstein replied 14 years, 8 months ago 4 Members · 11 Replies
  • 11 Replies
  • Gary Milligan
    December 14, 2011 at 9:16 pm
    [Darius Cornean] “I try to capture video files in Adobe CS 4.”
    Just to be sure, are you using Premiere Pro to capture your files?
    This is me – this is what I do – https://web.mac.com/garymmw
  • Darius Cornean
    December 14, 2011 at 11:48 pm
    Ya, for sur
    I use Adobe Premiere Pro CS 4 and the format files are .m2ts
    After I use Content Management Utility software from sony, i convert files in to .mts
    But still I dont have sound, only imgage.
    Sound is like a abuzz
    Thank you
  • Gary Milligan
    December 15, 2011 at 12:21 am
    To be honest, I don’t use Premiere Pro so I don’t know anything about that particular software. I shoot with a NX5 and import the .mts files into my Media 100 system using ClipWrap which transcodes them into ProRes. Works like a charm. ClipWrap also re-wraps .mts files (no transcoding and much quicker) – maybe you could try downloading their trial version and see if that might work for you… unless someone else here has a better solution using the tools you already have. Sorry I can’t be of more help.
    Here’s the link to the ClipWrap website: https://www.divergentmedia.com/clipwrap
    Good luck.
    Gary
  • Darius Cornean
    December 15, 2011 at 1:30 pm
    Thank you
    This software ClipWrap I think its only for mac
    I couldant find for PC
  • Gary Milligan
    December 15, 2011 at 4:39 pm
    Yes, you are correct – Mac only. There is similar software for PC but you will have to search and try for yourself.
    I’m curious though… I was under the impression that Premiere Pro could edit AVCHD files natively… or perhaps that is that only with the CS5 version. Have you been able to import other types of files without problems in the past?
    Good luck.
    Gary
  • Michael Johnston
    December 18, 2011 at 8:07 am
    The reason you have no audio is because the camera’s audio setting is Linear PCM (default setting) which can’t be used in CS4. You need to change the setting in your camera to Dolby Digital.
    The first thing I did when I got my NX5 was to shoot a short 2 minute clip, do a mic check, and try loading the test clip. I had the same problem. All I heard was white noise. Unfortunately, if you’ve been shooting all this time in Linear PCM, there is nothing you can do.
  • Michael Johnston
    December 18, 2011 at 3:07 pm
    I’ll just add that this is a good lesson for all to learn. When you get a new camera, do some test shoots and test EVERYTHING, including your edit software, before going out and shooting anything important.
  • Gary Milligan
    December 18, 2011 at 8:09 pm
    [Michael Johnston] “Unfortunately, if you’ve been shooting all this time in Linear PCM, there is nothing you can do.”
    ClipWrap will convert the Linear PCM to Dolby Digital. Yes, we’ve established it’s Mac only, but all is not lost if you have access to a Mac with ClipWrap. Surely there must be some PC software out there that will also convert the audio.(?)
    Gary
  • Michael Johnston
    December 18, 2011 at 11:16 pm
    You can try MPEG Streamclip as long as it’s not a long clip (over 5 minutes). Anything longer will usually crash the software. That’s really the only option. Yes, you can use ClipWrap but the original post said converting all the footage is not an option because there is so much of it. That’s why I said he’s stuck. There really is no other option other than getting access to a Mac and FCP 7.03. You can use LPCM audio with that. As far as Jim using CS4, he’s out of luck.
  • Darius Cornean
    December 20, 2011 at 4:40 pm
    Thanks to all of you for the ansewers
    @Michael Johnston
    Unfortunately the Sony NXCAM wasnt mine and I thought that was setup ok, but wasnt. They use FCP for editing that’s why wasnt a problem.
    In the way I read, the only chance that I have is to work with
    ClipWrap and then editing in FCP 7.03.
    But because I dont have acces on MAC can someone tell me a solution if I use Adobe Premiere CS4? the clips are longer than 5 minutes (for MPEG Streamclip).
    Maybe someone can tell me if I get CS5 I will be able to work with the m2ts files? If yes, my sistem is 32 bits, can I install Adobe CS5?, I heard that work only with 64bits sistem?
    Or maybe someone nows a way to convert the files?
    Thanks and I am waiting for your answer.
