Activity Forums Adobe Premiere Pro Editing mp4 makes file size much bigger
  • Editing mp4 makes file size much bigger
    Posted by Paul Campbell on July 21, 2016 at 5:38 pm
    I was emailed a little :15 video clip to which I wanted to add a :06 jingle. No biggy on the edit, just cropped some of the audio and squeezed the jingle in at the end. When I went to output it, the file size jumped from 2MB to 18MB. It was an mp4 file, resolution was something weird like 700×404 or something (don’t quote me on that, but it was something like that).
    As far as the output settings, I used H.264 as the preset (choosing mp4 from the dropdown list forced the resolution to a smaller size for some reason, so I didn’t use it) and chose the “Match source” for the other options. The only way I could get the output file size down to a reasonable 5MB was to choose a medium bitrate. It didn’t appear to affect the video quality, so I went with it. However, this isn’t the answer. Was the original mp4 that was sent possibly compressed using an expensive hardware compressor/encoder, maybe? I don’t understand why adding a simple :06 jingle could make the file size jump so high.
    Facepalm.
    Tero Ahlfors replied 10 years, 1 month ago 2 Members · 6 Replies
  • Tero Ahlfors
    July 21, 2016 at 5:51 pm
    You exported it with a higher bitrate than the original file.
  • Paul Campbell
    July 21, 2016 at 6:09 pm
    I do have Compressor to use, so that option exists. Gracias.
  • Paul Campbell
    July 21, 2016 at 6:11 pm
    I was searching for details of the original file to figure that out, but couldn’t find that info anywhere. Doesn’t Premiere allow me to view the original encoding bitrate?
  • Tero Ahlfors
    July 21, 2016 at 6:19 pm
    You know the size and duration so you could use simple arithmetics to figure that out.
  • Paul Campbell
    July 21, 2016 at 6:31 pm
    Oh sure, make me earn this why don’t you? 🙂
  • Tero Ahlfors
    July 21, 2016 at 6:35 pm
    It’s a basic skill that you’ll probably use a bunch so yeah. Earn it.
