Activity Forums Apple Final Cut Pro Legacy Editing movies with slides …
  • Editing movies with slides …
    Posted by Fredy Schwerdtner on June 19, 2009 at 1:51 pm
    Hi fellows …
    I need some advice … I will have to edit some movies with some slideshows made with 35m Pos Slides.
    The question is what could be a good size and resolution for scanning de 35m Pos Slides and add some FXs and movements to the slides in the timeline and also if someone knows a proper product for cleaning the slides … Could it be Isopropilic Alchool ?
    I will also use Motion ….
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    4GB 667 MHz DDR2 SDRAM
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.5.7
    Final Cut Studio 2
    Bret Williams replied 17 years, 3 months ago 3 Members · 2 Replies
  • Peter Wiggins
    June 19, 2009 at 2:11 pm
    Do all your moves on the slides with this excellent free plugin-
    https://www.noiseindustries.com/fxfactory/panandzoom/
    Peter
  • Bret Williams
    June 19, 2009 at 2:41 pm
    Since a slide is about an inch wide, you’ll need to scan at 800 dpi for SD and around 1600 dpi for 720p HD.
    I forget the actual width of a slide, but the math is pretty simple. You’ll need as many dots as your screen is wide. And more if you’re zooming or cropping.
