Activity Forums Apple Final Cut Pro Legacy Editing in Master Sequences that Auto Update Edits in “Affiliate” Sequences
  • Editing in Master Sequences that Auto Update Edits in “Affiliate” Sequences
    Posted by Caine Mitchell on June 14, 2010 at 8:38 am
    Hi there
    It was mentioned to me today that you can have a Master Sequence [containing say the end to end cut of an 80 min Feature] and several “Affiliate Sequences” [say 4 in the length of 20 min Reels that make up the 80 min Feature edit] – of these you are able to link the Affiliate Sequences to the Master Sequence so that say if you have trimmed a few shots in the Master Sequence the edits would then be reflected simultaneously in the corresponding “Affiliate Sequence”.
    So I’m not talking about Multicam editing but more like say [as analogy] using an excell database where if you make a change in one collumn, the result is reflected in the corresponding collumn.
    I have never heard of this before in FCP and am amazed that I have not. Is this a known function or are they mistaken with the capabilities inherent with another app.
    Thanks for your time reading this post 😉
    Caine Mitchell replied 16 years, 3 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    June 15, 2010 at 9:03 pm
    There’s something sort of like this only it’s the other way around. You can nest sequences in a “master” sequence, and if you change one of the original 4 shorter nested sequences (like in your example) the Master sequence will update.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Caine Mitchell
    June 16, 2010 at 2:22 am
    Hi Jerry
    Thanks for your reply.
    Yes I thought this would be the closest thing to what I originally thought possible.
    Definitely no other automated way than you can think of?
    Mitch
  • Jerry Hofmann
    June 16, 2010 at 1:06 pm
    There’s definitely no other way to have an edit change in one sequence update in another sequence. It’s a good workflow though. While your editing, it’s always easier to work with a shorter sequence than a long one, so it makes sense that the software would be designed to work as I described above.
    Jerry
  • Caine Mitchell
    June 16, 2010 at 11:27 pm
    I agree. And thanks for the additional confirmation Jerry.
    Kind regards, Caine.
    Mitch
