Activity Forums Apple Final Cut Pro Legacy Editing in HDV then SD
  • Editing in HDV then SD
    Posted by Dave Beaty on October 1, 2007 at 9:43 pm
    I just finished down converting my HDV project to SD 10-bit uncompressed and I’m happy with this workflow method that avoids the very bad quality conversion associated with converting HD sequences to SD sequences natively in FCPro.
    The old stand by methods of exporting to QT to downconvert or using a hardware realtime down converter aside, I needed to EDIT the material in HD and SD, ending up with two sequences.
    Using Media Manager’s recompress option, I was able to keep the same quality as the QT export route. The clips look fanatastic. Using the Custom export template you can change the output to suite your needs.
    One question, can I output to both a stereo down mix and two channels of mixed mono from FCPro without doing it on an analog mixer? I use the Multibridge which I think has embedded SDI and AES/EBU outs.
    Dave Beaty
    Dreamtime Entertainment
    1625 SE 46th St
    Cape Coral FL 33904
    239-549-4081
    800-446-7575
    dave@dreamtimeentertainment.com
    http://www.dreamtimeentertainment.com
    Walter Biscardi replied 18 years, 11 months ago 2 Members · 1 Reply
  • Walter Biscardi
    October 1, 2007 at 10:36 pm
    [Dave Beaty] “One question, can I output to both a stereo down mix and two channels of mixed mono from FCPro without doing it on an analog mixer? I use the Multibridge which I think has embedded SDI and AES/EBU outs.”
    Yes, you simply do this in the audio tracks themselves. You create a stereo mix and a mono mix. If you need to do this in one pass on four channels, you simply assign the stereo mix to one pair and the mono mix to the other pair.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
