Activity › Forums › Apple Final Cut Pro Legacy › Editing in 23.98 fps Timeline
  • Editing in 23.98 fps Timeline
    Posted by Johnb on October 17, 2007 at 11:32 pm
    I’ve got a lot of footage I shot at 24p which I used Cinema Tools to remove the pulldown, but since the project is a documentary and I’m using a lot of other old footage that was shot on standard DV years ago, will I be able to edit that footage in a 23.98 fps Timeline as well? Should that older footage just be captured at 23.98 or will that ruin it? Is there a way to convert it to 24p?
    I’m planing on using After Effects / Motion once the rough cut is put together and am worried that the graphics won’t sync up. Any thoughts?
    Also, I’m correct in doing the pulldown on all my clips before doing any editing, right? And I should be editing in a 23.98 fps Timeline?
    Sean Oneil replied 18 years, 11 months ago 2 Members · 3 Replies
  • Sean Oneil
    October 18, 2007 at 5:47 am
    [johnb] “Should that older footage just be captured at 23.98 or will that ruin it? Is there a way to convert it to 24p?
    If it was shot natively 29.97, you need special effects tools to convert it. Nattress plugin does this, and there are higher end tools as well. A Teranex machine will also do this.
    [johnb]
    Not sure what you mean. In AE and Motion your compositions can be whatever framerate you want.
    [johnb]
    Also, I’m correct in doing the pulldown on all my clips before doing any editing, right? And I should be editing in a 23.98 fps Timeline?”
    Yes and yes.
  • Johnb
    October 18, 2007 at 11:38 pm
    Do I need to purchase the Nattress plugin? Isn’t there a way to convert 29.97 fps standard DV to 23.98 in Cinema Tools?
  • Sean Oneil
    October 19, 2007 at 12:08 am
    [johnb] “Do I need to purchase the Nattress plugin? Isn’t there a way to convert 29.97 fps standard DV to 23.98 in Cinema Tools?”
    No, not unless it was shot in 24p mode.
