Activity Forums Apple Final Cut Pro Legacy Editing in 16:9 ratio without the letterbox black bars
  • Editing in 16:9 ratio without the letterbox black bars
    Posted by Gnwanya on December 1, 2006 at 9:28 am
    Hi guys,
    I hope you can help me out here. I’ve been trying to capture native hdv onto final cut pro, which i will then export into After effects, How ever ever time i drop the clips onto a sequenced timeline that is setup for HDV 16:9 ratio, i keep getting the letterbox black bars. And if i resize the sequence using the setup options, i often get black bars to the side of the footage. When i render out, as an uncompressed file, the black bars are obviously visible.
    Can someone tell me at what point am i going about the process wrong?
    Gus
    G5 1.8 Dual / 3.5GB ram / FCP 5 /
    Gnwanya replied 19 years, 9 months ago 2 Members · 2 Replies
  • Liam Stephens
    December 1, 2006 at 12:55 pm
    Hmmm definitely something with your settings. The best way to go about getting the right settings is to click on “Easy Setup” in the Final Cut Pro menu and select the correct HDV setting, all sequences u create should be the right setting, specially if u captured at the setting.
    good luck
    L
  • Gnwanya
    December 1, 2006 at 2:11 pm
    Thanks for the advice. Its much appreciated. I’ll look into it
