Activity Forums Zaxwerks editing illustrator layers problem
  • editing illustrator layers problem
    Posted by Phil Biggs on September 7, 2005 at 10:11 pm
    Hi there,
    I’m having a nightmare trying to reload / replace objects in Invigorator once editing the layers in Illustrator. The original file was imported with ‘via layers’ enabled but, after going back to Illustrator to tweak a few things (keeping the original layer structure intact) nothing happens when I click on the reload button in the setup window. When I try to replace the objects with the oversaved Illustrator file, it says there are no usable vectors (the vectors are fine as they work in a new test invigorator comp). Anyone any ideas? I really don’t want to build the model again from scratch every time I edit something in Illustrator.
    Cheers,
    Phil
    Phil Biggs replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
