Activity › Forums › Apple Final Cut Pro Legacy › Editing HDV on MacBookPro
Posted by Jbooth on June 21, 2006 at 4:52 pmIs it possible to edit native HDV footage on my MacBook Pro? It has 2 GB RAM , but I can’t even watch the footage without a dropped frames warning coming up almost immediately. I have experimented and found that the HDV Apple Intermediate codec gets rid of the dropped frames problem, but it takes FOREVER to render. Is there a better solution?
Boyce Johnson replied 20 years, 3 months ago 6 Members · 11 Replies -
Simon Carlson-thies
June 21, 2006 at 5:10 pmIf your looking for RT you’ll be unlikely to find it on a laptop, what speed is your hard drive? 5400 or 7200?
If 5400 you might try using an external 7200rpm drive for media over FW…
Also if you don’t have a scratch drive you might try that too..
But in terms of RT a laptop won’t cut it, you’ll need to get a desktop…
Simon Carlson-Thies
David Jones
June 21, 2006 at 5:21 pm[Simon Carlson-Thies] “But in terms of RT a laptop won’t cut it, you’ll need to get a desktop”
The MacBook Pro is as fast, if not faster than a bunch of “Desktops”.
But as stated, you will want to get an external drive system for your video editing. -
Jbooth
June 21, 2006 at 5:25 pmJust tried using a 7200 rpm lacie external drive, imported one HDV clip off of it into FCP on my MacBook and same thing… dropped frames warning as soon as I try to play the clip… any suggestions?
Kevin Monahan
June 21, 2006 at 5:37 pmDitch the LaCie and get a FireWire 800 drive like a G-Raid.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Simon Carlson-thies
June 21, 2006 at 6:12 pmYou can keep lacie, but def. use FW800, lacie is not the problem its FW400 thats the problem…
Simon Carlson-Thies,
Digital Light Graphics And Animation -
Jbooth
June 21, 2006 at 6:29 pmThanks for the input… that’s one thing I still haven’t put together is a 7200 rpm external drive winth FW800 on both ends… working on it…
Ed Dooley
June 21, 2006 at 8:00 pmYou’ve got a MacBookPro, why are you even thinking of FW? For the absolutely fastest performance
on your laptop, the new SeriTek Express 3/4 SATA card is the fastest thing you can get. The dual-core
laptop is plenty fast enough for HDV, and with SATA drives (get 2 and a 2 drive case and stripe them),
there’s nothing faster.
My 2 cents,
Ed -
Kevin Monahan
June 21, 2006 at 8:17 pmSounds good Ed. One thing that you can never overkill is drive speed. 😉
Kevin Monahan
fcpworld.com
Pres. SF Cutters -
Ed Dooley
June 21, 2006 at 9:36 pmIt’s mostly that I’m jealous. I’m using a 17″ PB for location editing and my 2 drive FW800 RAID is the best I can do.
I can do some UC8bit with it, but mostly use it for my Betacam to DVC50 editing.
I would love a SATA 2 drive array. Seritek makes a cardbus card for SATA, but I don’t think the performance gain is worth
the change. It seems that because of the PCMCIA slot bus, you don’t get the full speed of SATA.
And besides, the more I “suffer” with my FW800 setup, the more likely I’ll spring for a new Macbook Pro soon. 🙂
Ed[Kevin Monahan] “Sounds good Ed. One thing that you can never overkill is drive speed. ;-)”
