Activity Forums Avid Media Composer Editing HDV in Media Composer
  • Editing HDV in Media Composer
    Posted by Jaclyn Lee on February 5, 2010 at 12:13 am
    I’ve checked both the Avid and HDV forums, but couldn’t find an answer. I am capturing footage from a Sony HVR-Z7U into Media Composer. The default resolution is HDV 1080i, which I assume is the highest resolution possible. Is there a way to create lower resolution files that I can off-line with, so that render times etc for effects won’t take as long? We are planning to online this in-house, as the final product is QT or Flash for streaming on the web.
    Thanks.
    Jaclyn Lee
    MacPro
    Avid Media Composer 4.0.2
    Keith Sonstegard replied 16 years, 7 months ago 3 Members · 4 Replies
  • Bill Ravens
    February 5, 2010 at 12:27 pm
    Can you not consolidate imported clips to DNx36 for the sake of editing, then replace that with the hi quality files when cutting is done?
  • Jaclyn Lee
    February 5, 2010 at 3:20 pm
    Hi Bill,
    Thanks. When I capture the footage, the only option I have in “resolution” is HDV1080i. When I try to transcode, the only options I have are: AVC-Intra 50, DNxHD-TR 145, XDCAM HD 17.5 mbit and 35 mbit.
    The only effects I have are fades, titles, dissolves. Not having edited in HDV before, I’m concerned with the amount of time it will take to render the fx. Is there a huge difference between the HDV 1080i resolution and the DNxHD codec?
    Thanks.
    MacPro
  • Bill Ravens
    February 5, 2010 at 7:00 pm
    Another possibility is to transcode your file prior to importing them into Avid. There are several applications that will do this, most notably Quicktime Pro and Sorenson Squeeze.
  • Keith Sonstegard
    February 7, 2010 at 8:59 pm
    If you have a Nitris DX or Mojo DX you could digitize via the HD SDI input/output and then select an Avid codec that’s not HDV which should improve your computer processing.
    If you want to down-rez. Have the HVR Z7U do it and capture via Firewire using Avid’s DV25 codec. In the iLink menu, you can change your VTRs output to 16×9 or 4:3 SD. One word of caution…batch capturing (for up-rez) may be difficult. I haven’t had much luck finding timecode sync while tying to batch capture with DVcam or HDV footage.
    Hope that helps.
    Keith
