Activity Forums Apple Final Cut Pro Legacy Editing HDV as DV
  • Editing HDV as DV
    Posted by Max Kaiser on June 22, 2005 at 4:47 pm
    Okay, I’ve read all the posts I can find with HDV in them, and I don’t really see an answer to this question. There are lots of new settings with HDV, and I’m just trying to get to a solution for capturing HDV, converting to NTSC DV, editing, and outputting DV25 material. So, here is how I am doing it.
    Capture using HDV codec into FCP.
    Export from FCP via quicktime conversion.
    For export settings, set to DV/DVCPRO NTSC, maximum rez., 4:3, interlaced, current fps
    Audio – Apple Lossless 48khz.
    Once this is done.
    Reimport clip, and set sequence settings to:
    Frame Size: NTSC DV (3:2)
    Pixel Aspect Ratio: NTSC CCR601
    Field dom.: Upper
    Quicktime Compressor: DV/DVCPRO NTSC.
    Audio; 48Khz, 16 bit.
    With these settings, I get an excellent looking picture (heck, it’s all good compared to my old VX1000), and I can easily edit the video. I do get a red render bar on the audio which I don’t understand because my sequence settings and the export settings match, but…
    Would this be the correct (most efficient/best picture quality without HD equip) set up for video that is going to only go to NTSC, and which must have final output through DV25 (firewire). In otherwords, I don’t have blackmagic board, or any need for HD output.
    Thank for responding, or pointing me to a previous post I missed.
    Max
    Max Kaiser
    Hand Crank Films
    http://www.handcrankfilms.com
    Dual G5, 4.5 GB
    FCP 4.5
    OS 10.4
    Max Kaiser replied 21 years, 3 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    June 22, 2005 at 4:53 pm
    I think the faster way to get to the same result would be to let your camera/deck do the downconversion… I’m pretty sure that the Sony gear will output the HDV as DV during playback, so you’d just capture it as DV in the first place.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark Maness
    June 22, 2005 at 6:09 pm
    Yes, it does. That’s how I’m using it most of the time.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Max Kaiser
    June 22, 2005 at 6:12 pm
    Haha! Thanks, that is quite a bit easier. It took me all morning to figure out the camera downconvert – who knew I had “i.link”? Anyhow, works great now, thanks very much!
    Max
    Max Kaiser
    Hand Crank Films
    Dual G5, 4.5 GB
    FCP 4.5
    OS 10.4
  • Peter
    June 25, 2005 at 3:27 pm
    Are you using the Sony HVR-Z1 by chance with FCP 4.5? Shooting 1080i and capturing/editing DV-NTSC codec 720×480 16:9?
    Is this possible or do I need to be on FCP 5 for some reason.
    Thanks in advance.
  • Max Kaiser
    June 27, 2005 at 3:09 pm
    I’m using 5, and an FX1. But I don’t see why it wouldn’t work with 4.5. Also, I am not capturing it 16×9, but 4×3, since that is how most people will be seeing my DVD.
    Max
    Max Kaiser
    Hand Crank Films
    Dual G5, 4.5 GB
    FCP 4.5
    OS 10.4
