Activity › Forums › Adobe Premiere Pro › Editing HD in Adobe Premiere Pro CS4
  • Editing HD in Adobe Premiere Pro CS4
    Posted by Donovan Werts on May 9, 2011 at 4:34 am
    I’m planning on purchasing a new computer to edit HD video. The video format will be Cineform HD AVIs (converted AVCHD files from a Sony HD Camera).
    Could someone take a look at this system I’ve configured at the Digital Storm website and let me know if this is over-kill, or if the system would work well with HD.
    Here’s the link: https://www.digitalstormonline.com/comploadsaved.asp?id=537200
    My main questions are:
    Should I get a solid state hard drive for the system? (most of the footage will be on external hard drives)
    Is the Radeon HD 6990 4GB Video card a good choice?
    Is there anything missing from this system configuration that I’d need for HD editing?
    Thanks very much for your time and feedback in advance, Donovan
    Donovan Werts replied 15 years, 4 months ago 3 Members · 4 Replies
  • Ann Bens
    May 9, 2011 at 7:58 am
    If you want to take advantage of MPE hardware you need a Nvidia graphicscard.
    https://www.adobe.com/products/premiere/tech-specs.html
  • Donovan Werts
    May 9, 2011 at 3:03 pm
    Thanks for your reply. I’ll need to do a little research. I don’t know about “MPE Hardware”.
  • John Young
    May 10, 2011 at 4:23 pm
    This is depending on your budget but…
    You need to focus your money on 1)Adobe Software 2)Graphics Card and 3) RAM.
    The MPE Hardware mentioned above, is the Mercury Playback Engine. But it is only on PP CS5 not on CS4 which is what you are looking at. It uses the graphics card for a lot of acceleration (real-time effects, little to no rendering time) and it really made my editing workflow faster.
    Again, all this depends on your budget but if you already have CS4 consider an upgrade to CS5.5 and get a graphics card that is compatible with the MPE and you could really be smoking.
    John
    http://www.johnathanyoung.com
  • Donovan Werts
    May 11, 2011 at 12:03 am
    Thanks John, that helps a lot!
