Editing H.264 files in Vegas
I have used a Contour HD camera to capture some footage. The camera saves files in the H.264 codec in a .mov container.
I have tried to edit these files in Sony Vegas and the process is painfully slow. A bit of googleing showed that H.264 needs alot of processing power to decode, so it is difficult to decode on the fly. That’s all fine and dandy.
So now my biggest question is how to get around this?
I would think that I would convert the H.264 files to a lossless format that is easier to edit. So I tried both Huffyuv and Lagarith. I used VirtualDub to produce avi files in each format. All the files play back in Media Player Classic just fine.
Now, I drop the files and Vegas and it’s a no-go. When I drag the files on Vegas, it says “None of the files dropped on Vegas Movie Studio Platinum could be opened.” When I select the files by File –> Import, Vegas says: “Warning: An error occurred while opening one or more files. The number of channels is not supported.”
I’ve tried this solution and gotten the same result on two different computers. One had XP the other ran Windows 7. Both had Vegas Movie Studio Platinum 8 installed and both computers had overclocked (and very stable) quad core CPUs, 2GB or 4GB of RAM, and a WD Raptor or SSD installed.
Am I doing something wrong? Have I missed something? Any help or advice is greatly appreciated.
