Activity Forums VEGAS Pro Editing Frames
  • Editing Frames
    Posted by David Katauskas on October 19, 2010 at 2:14 am
    Using Platinum 9.x.
    Let’s say that I’ve got a short clip of about 100 frames, and I want to manually edit each of those frames as I would in a picture editor such as GIMP or PhotoShop. Is this possible? Other than exporting each frame individually, how might I do this?
    Danny Hays replied 15 years, 10 months ago 2 Members · 1 Reply
  • Danny Hays
    October 19, 2010 at 5:26 am
    If your want to edit all of them in the same way, just add the effect to the track header. Eack frame can be done by adding an effect to each frame, zoom in far enough and see the effect icon on each frame or clip. If it’s one stream of 100 frames, zoom in till you can see each frame and put the curser between each and hit the “S” key for split. This will make a frame sequence so to speak, 100 seperate frames. Then you can put an effect on each frame. Hope this helps, Danny Hays
