Activity Forums Apple Final Cut Pro Legacy Editing frames as a group in Final Cut.
  • Editing frames as a group in Final Cut.
    Posted by Philip Reid on June 24, 2009 at 2:49 pm
    Hi there,
    Working on a half rotoscoped, half real footage music video just now. The idea is to have the linear rotoscoping looking as if it is being drawn out on the realtime footage of the book. Having imported the frames, I am having issues trying to resize and reposition the frames as a group?
    I have tried exporting them as a clip in order to resize over the footage as one piece of footage but then I get a solid black background making the drawing disappear.
    Any suggestions? Cheers!
    Nick Meyers replied 17 years, 3 months ago 6 Members · 5 Replies
  • Victor Perez
    June 24, 2009 at 3:44 pm
    What did you export the clip as?
    Did you try Animation Millions of colors +
    The plus is your alpha
    hope that helps
    Victor
  • John Steventon
    June 24, 2009 at 3:46 pm
    Not sure if I’ve got the right grasp of what you’re trying to do, but have you tried nesting all the frames into one big chunk on V2 (assuming V1 is the book) – and working with that? (select all frames, alt+c to nest)
    Or am I off-base?
    John Steventon
    JKL Editing
    http://www.jklediting.com
    “Success is merely a failure to imagine more…”
    2.26 Dual Quad Nehalem Mac Pro (11Gb Ram) / 2 x 23inch Apple Displays / FCP 6.05 / Decklink HD Extreme 3 + Multibridge / JVC HD Monitor / Atto Celerity Fibre Channel with Infortrend 6.5tb Raid 5 Storage / And a smile.
  • Matt Larson
    Have you tried nesting the frames? (Highlight the frames in the sequence and then chose Nest from the Sequence menu I think)
    Then, to resize, etc you will need to drag the nested sequence from the timeline into the Viewer window and click the motion tab.
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
  • John Christie
    June 24, 2009 at 4:46 pm
    The best way to deal with individual frames is to convert them to an animation codec mov with alpha (millions +)
    Open Quicktime player and choose open image sequence. Then export the save the resulting QT movie.
    Trying to deal with thousands of stills in FCP will bog the program down.
    Cheers
    John Christie
  • Nick Meyers
    June 25, 2009 at 2:32 am
    “Trying to deal with thousands of stills in FCP will bog the program down.”
    i’ll second this,
    which is to say NESTING IS BAD for what you want to do.
    as John says, use QuickTime to convert the Image Sequences into video
    to preserve quality of the image sequence, PLUS the alpha people are suggesting Animation codec,
    but that’s pretty unwieldy to work with in an off-line.
    i understand that going OUT of FCP, Animation is the only codec that carries an Alpha,
    but coming in?
    surely other codecs can carry an alpha channel?
    nick
