Activity › Forums › Apple Final Cut Pro › Editing for multiple screens with FCPX
Matthew Woods replied 1 year, 12 months ago 8 Members · 12 Replies
Mads Nybo jørgensen
September 2, 2024 at 9:59 pmHey Rod,
Sounds right, but how does the client want to play the file?
Do they have the equipment installed?
If so, can you run a test to make sure that it works, and that the screens are perfectly alligned?
Mads -
Matthew Woods
September 3, 2024 at 6:10 pmSounds about right. I usually render an all screens pro-res master from Final Cut. Then depending on the player/players I either crop and cut it up into individual vids for each projector, or remap it to fit the requirements of the player.
A recent 4 screen project that I worked on was installed on a brightsign, and needed a single 8k file where each quadrant was the output of 1 screen. The screens were different sizes and orientations, so I had to scale, rotate and crop my edited master vid to fit each quadrant.
A little bit of self promotion. If you are dealing with screens that are in perspective, or are hitting multiple screens with 1 projector you might find this tool that I wrote helpful. It will blow up a perspective portion of your vid to full screen so you can use the native corner pinning tools on-site to map it into its final location.
https://fxfactory.com/info/reversecornerpin/
AE’s “Power Pin” tool will do this too, but I wanted the ability to do it in Final Cut.
Good luck,
-Mat
