Activity › Forums › Apple Final Cut Pro Legacy › Editing footage from the Panasonic HVX200A
  • Editing footage from the Panasonic HVX200A
    Posted by Lawrence Kim on December 4, 2008 at 7:29 pm
    Hello,
    I just shot a project using the Panasonic HVX200A camera. We shot 720p, 24pn. Location sound was recorded at 23.976 fps, .wav poly, 24 bit, 48 kHz.
    I’m about to start editing using Final Cut Studio 2. Could someone please tell me which audio/video settings I should use when I set up my Final Cut project?
    Many thanks,
    Lawrence
    Mark Suszko replied 17 years, 9 months ago 2 Members · 1 Reply
  • Mark Suszko
    December 4, 2008 at 10:48 pm
    Same as your source. Otherwise, you add rendering work. You can so thsi thru easysetups or make acustom setup, just menu thru all the setigns and save it.
    I try to edit in the native format of whatever comes in, then if the output has to be something else, I’ll render that out at that stage when the project is done.
