Activity Forums Adobe After Effects Editing footage after Twixtoring
  • Editing footage after Twixtoring
    Posted by Dan Hashemi on October 29, 2011 at 9:52 pm
    I recently edited some footage with Twixtor (speed ramps), and have it looking like I want. Now, however, during the slow-motion portions, I want to be able to stop the frame, freeze it, make some edits, hold for a few seconds and then continue on.
    In Premiere, I’d just cut the clip, do what I want and then continue the clip after…in AE I’m not sure how this is accomplished.
    Do I just have to duplicate the twixtor’ed source file in the timeline and then change the IN/OUT points?
    Is there a better way to do this?
    Dan
    Jeff Brown replied 14 years, 10 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    October 30, 2011 at 3:26 am
    If it’s easier in PPro, then do it in PPro. You can then use Dynamic Link across both products or simply copy the spliced clips from PPro and paste them into an AE timeline.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Jeff Brown
    October 31, 2011 at 5:04 pm
    You can use “time remapping” in AE to hold frames. But it can get tricky to remember where you are in the clip so as not to mistakenly start re-timing the footage again.
    I’d use Premiere too, if possible.
    -Jeff
