Activity Forums Apple Final Cut Pro Legacy Editing EX1 Footage
  • Editing EX1 Footage
    Posted by Peter Chambers on August 5, 2009 at 8:21 pm
    Hi there,
    I just purchased a Sony PMW-EX1 kit and I’m wondering if there is some combo of software that will allow me to edit on my current setup.
    I’m running Mac OS X 10.4.11
    Dual 2 GHz PowerPC G5
    6 GB DDR2 SDRAM
    L2 Cache (per CPU) 1 MB
    Bus Speed 1 GHz
    GeForce 6600LE graphics card
    I’m running Final Cut Pro 5.1.4
    (I also have a Macbook Pro Intel Dual Core that I will be capturing the SxS cards to if that helps. The Final Cut version, 5.1.4)
    All help would be greatly appreciated. Thanks.
    Peter Chambers replied 17 years, 1 month ago 2 Members · 2 Replies
  • Chris Borjis
    August 6, 2009 at 12:03 am
    you will need a minimum of FCP 6.03
    and the xdcam ex software from sony that is G5 compatible.
  • Peter Chambers
    August 6, 2009 at 3:30 am
    Thanks Chris…
    I assume you mean the Sony Transfer Tool? Sony put out this FCP plug-in that apparently transfers the clips. I found a download here:
    https://servicesplus.us.sony.biz/SoftwareFreeDownload.aspx
    I’m downloading it now and going to try it out once I’ve upgraded my Final Cut Pro to version 6.0.3.
    Thanks again.
