Activity Forums Apple Final Cut Pro Legacy EDITING DVCPROHD on FCP
  • EDITING DVCPROHD on FCP
    Posted by Gary Taylor on November 26, 2007 at 10:20 pm
    DVC PRO HD Panasonic Varicam AJ-HDC27
    Editing on: A standard MAC BOOK PRO laptop with 2gig of ram
    Firewire 400
    OS: 10.4.11
    Final Cut Pro: 5.1.4
    001:00:00 (1 hour) = 58GB
    The reason for this mail is that I have recently shot a 3 minute Music video using the format listed above, no slow motion. I was wondering how difficult will it be to edit this project in this format using FCP. Will it be possible to perhaps edit at quarter resolution and edit in real-time.
    My main concerns are:
    1 Do I need any plugins to edit varicam material?
    2 Project settings? DVCPRO HD 720P25 or 1080i50
    3 RT setting
    Playback video quality?
    Dynamic
    High
    Medium
    Low
    4 Playback frame Rate?
    Dynamic
    Full
    Half
    Quarter
    The footage looks great so any suggestion on how to edit this material would be an invaluable contribution to this project.
    Regards
    Garry Taylor
    Dylan Reeve replied 18 years, 10 months ago 4 Members · 5 Replies
  • Walter Biscardi
    November 26, 2007 at 11:04 pm
    [Gary Taylor] “1 Do I need any plugins to edit varicam material?”
    No
    [Gary Taylor] “2 Project settings? DVCPRO HD 720P25 or 1080i50”
    Not sure if FCP 5.1.4 supports 720/25. You might have to make your own preset or it doesn’t work.
    1080i/50 does work
    [Gary Taylor] “3 RT setting
    Dynamic
    High
    Medium
    Low”
    Dynamic is what I use on the desktop machines. Just adjust this as needed for maximum playback on your machine.
    [Gary Taylor] “4 Playback frame Rate?
    Dynamic
    Full
    Half
    Quarter”
    Full
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Gary Taylor
    November 27, 2007 at 12:38 am
    Thanks Walter I’m hiring a 1400 deck tomorrow so I’ll try your advised setting out once I have digitized, But are you sure I need to work at 720p25 and not 1080? I’m not sure what picture size the tapes were recorded at. Hopefully this project will go out to broadcaster in the UK and I want to give them the best quality output. Thanks for getting back to me, I read your bio and and visited your web site it looks like your doing some really cool stuff. Cheer’s for the advice mate. Garry
  • Walter Biscardi
    November 27, 2007 at 1:17 am
    [Gary Taylor] “I’m not sure what picture size the tapes were recorded at.”
    Varicam can only shoot 720 so it’s going to be 720/24, 720/25 or 720/60 unless they shot at some off frame rate.
    Again, not sure if FCP 5.1.4 can work with 720/25. I’m almost certain there is not an Easy Setup for that, but you might be able to create a Custom Preset to make that work.
    Read my Blog!
  • Gary Adcock
    November 27, 2007 at 2:36 pm
    [Gary Taylor] “I’m not sure what picture size the tapes were recorded at. “
    Varicams only record 720p signals.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Dylan Reeve
    November 27, 2007 at 9:17 pm
    Danger danger!
    You can not digitise 25fps material shot on a Varicam into a 25fps project in FCP (or Avid) via Firewire.
    The problem is that Varicam always operates at 60Hz (or 59.94Hz) no matter what it shot on it. The signal coming from the Firewire on the AJ-HD1400 will always be at 60Hz.
    For this reason you simply cannot capture into a 50Hz-based project (anything 25fps or 50fps) from Firewire.
    The HD1400 has a mode called ’25(HD)’ designed to cope with this, which generates 50Hz signals (specifically 1080i50 25PsF) from the 25fps Varicam footage. However it will ONLY output via HD-SDI and HD-Component – the Firewire signal will still be carrying 720p at 60Hz.
    The only way to work with Varicam at PAL framerates is to capture using an AJA or Decklink card. the IoHD would be another option, but with only FW400 on your laptop, isn’t going to work.
    The only software I am aware of which can capture the 25fps footage from the 60Hz Firewire signal is Grass Valley Canopus Edius Broadcast. Which is a Windows application.
    This has been my nightmare for the past two months.
    Our workflow now is using the ’25(SD)’ mode on the deck to capture Analogue SD video out (Firewire is still 720p 60Hz in that mode) into Avid for offline. Online will be in FCP, using the ’25(HD)’ mode on the deck, HD-SDI with a Decklink card.
