Editing clips to playhead & inserting clip between 2 clips -DOUBTS
I have 2 doubts/issues in PP:
1.I’m trying my best to use more of keyboard shortcuts. So after selecting in/out points on a clip & I want to add it to the timeline TO THE POINT WHERE THE PLAYHEAD/MARKER is placed,how do I do this ? When I press the ‘,’ comma , it APPENDS the clip to the end of the sequence.
2. What is the easy way to insert a clip between 2 clips in a sequence ? ( Apart from using mouse,dragging the entire set of clips on the right a little further away ,creating some space in between,then inserting the clip there using the mouse and then RIPPLE Delete the gap) )
Thanks in advance !
