Activity Forums Adobe Premiere Pro Editing Basics Questions
  • Editing Basics Questions
    Posted by Alex Udell on June 23, 2005 at 5:56 pm
    Hi All…
    just digging into Premiere Pro and need some editing advice…
    Is it possible to do a Mult track Lift edit?
    In the Sequence windows of many NLE’s you can extend a frame selection (In to Out) across multiple tracks by muti selecting the corresponding tracks themselves. I can’t seem to do this. Only one video or audio track can be slected.
    So for example, if you want to lift or extract a selection that say is within the heads and tails of multiple vertical events along the sequence, it seems to me that the only way to do this is to razor (Ctrl K) accross all tracks and then marquee select the new events and press delete.
    Can’t the In and Out points be used as the basis of the frame selection accross multiple tracks and then multi slect tracks to extend the In to out range slection vertically over selected tracks?
    What am I missing?
    Alex Udell
    lead demo artist and trainer
    PEI Graphic Technology http://www.profileeast.com
    My Reel: https://alexudell.no-ip.biz
    COMBUSTION EXCHANGE FTP: ftp://combustionexchange.no-ip
    Logon: combustion_user
    PW: learn
    Alex Udell replied 21 years, 3 months ago 2 Members · 3 Replies
  • Tim Kolb
    June 23, 2005 at 6:18 pm
    You’ve happened on one of the most flagged feature gaps in PPro by former users of Discreet *Edit…
    At this point I know of no way to do what you want without the uber-razor and multiple clip select as you pointed out.
    TimK
    Kolb Syverson Communications
    Creative Cow Host
    2004, 2005 NAB Post Production Conference Premiere Pro Technical Chair
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Alex Udell
    June 23, 2005 at 7:27 pm
    Hi Tim…
    Good to know. As I am also a previous edit user (but have touched many NLE’s now) I was beginning to question my sanity. 🙂
    Thanks for the heads up.
    Alex Udell
    PW: learn
  • Alex Udell
    June 23, 2005 at 8:12 pm
    Hi Tim and all…
    another one for you…
    Are there source side effects like Audio gain in the source.
    i.e. Adjust the source gain, and it’s automatically updated where it’s use din the destination sequence?
    you could do this via nesting I suppose, but what happens to source time code when you do that?
    Thanks…..
    Alex Udell
    PW: learn
