Activity Forums Adobe After Effects Editing audio
  • Editing audio
    Posted by Luger54 on December 6, 2006 at 1:22 am
    Hello Everybody
    I would like to ask how i can fade my audio layer in and out? I have been messing around with the graph but it does not seem to work. The audio layer is in wave format if that makes any difference.
    Greg
    Luger54 replied 19 years, 9 months ago 2 Members · 2 Replies
  • Broken
    December 7, 2006 at 6:16 pm
    Are you using keyframes to take your audio from 0 dB to -85 dB, or whatever AE calls “totally faded out”?
    If you have no other choice than to use AE for audio work, then you have to use it. But even a video editing application is better suited to audio editing than AE.
    And an audio editing application is the best choice of all. Heck, there are even some freebie audio editors out there. If you’re on a Mac, check out Audacity.
    Dave LaRonde
    Sr. Promotion Producer
    KCRG-TV
  • Luger54
    December 14, 2006 at 11:48 pm
    Hi Dave
    Thanks for your reply. Yes i tried to drag the keyframes up and down, but it did not seem to do anything at all so i ended up editing my audio using Audiacity which is an excellent program, cheers!!
    Greg
