Activity Forums Adobe Premiere Pro Editing Audio Track Key Frames
  • Editing Audio Track Key Frames
    Posted by David Neumann on July 17, 2009 at 10:15 pm
    Hi All,
    I’m working in Premiere Pro CS2. I’ve been editing the music track using the key frames. Using key frames I lower the audio when someone is talking and raise it when they’re not. Pretty straightforward.
    Some of the interview material is now being taken out. After deleting some dialogue I’ll do a ripple delete or lasso the next section and bring it up. Problem is the key frame retain their former position so now I have to go back and re edit the key frames. I know I can select the key frames and drag them forward but I usually raise the levels or trigger the bezier’s creating another headache.
    Is there a simpler way to keep the key frames lined up?
    Thanks in advance for your help
    David Neumann replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
