Activity Forums Adobe Premiere Pro Editing Audio in Adobe Premiere Pro
  • Editing Audio in Adobe Premiere Pro
    Posted by David Smooth on February 20, 2017 at 11:23 pm
    So I’ve got a piece of audio with some dialogue and some horror movie mood music in the background. The mood music is louder than the dialogue. Bear in mind I’m not talking about a low rumbling hum I mean this is full on horror screeching kind of music.
    Any tips on how to clean up the audio, get rid of as much of the music and just retain the dialogue?
    I’ve tried Denoiser, Decrackler, DeEsser and DeHummer and no luck yet…
    Trevor Asquerthian replied 9 years, 7 months ago 4 Members · 3 Replies
  • David Roth weiss
    February 21, 2017 at 12:28 am
    If they are mixed there is nothing you can do. You can only affect changes in relative levels if you have split tracks with separate music, separate dialogue, and separate sound effects.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Aaron Wolski
    February 21, 2017 at 3:09 am
    Adobe Audition or Audacity can help tackle this problem, though it likely won’t be perfect.
    Bring your audio file into audition and then go to effects > stereo imagery > center channel extractor
    From here you want to play around with the presets in hopes of lowering the background.
    Hope this helps.
  • Trevor Asquerthian
    February 21, 2017 at 6:14 am
    If you can get hold of (Shazam) the clean music and sync it with the mix, you may be able to phase invert that and thus remove it. You’d have to match the music level in the mix.
    Likelihood is it won’t work though…
