Activity Forums Apple Final Cut Pro Legacy editing audio for multiple cuts
  • editing audio for multiple cuts
    Posted by Jay Fishback on December 14, 2011 at 10:50 pm
    I understand this question might technically belong in soundtrack pro.
    I have a video I shot for a client interviewing various people. I have the video cut up and instead of going through each clip and sending it to soundtrack to clean it up (around 8 minutes total in length.) I was wondering if there was a way to send the whole thing over at once and apply affects on the voices. I have tried sending it as multiple track and audio file but neither one has worked. Yes, you have to go in each individually is an acceptable answer too.
    Jerry Hofmann replied 14 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    December 15, 2011 at 2:08 pm
    Well… if a single change to all clips will suffice, couldn’t you simply copy the first change to all clips?
    You could simply export the audio tracks as a single file, then send that file to Soundtack pro.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
