Activity › Forums › Apple Final Cut Pro Legacy › Editing Audio beyond 25fps. Dialogue editing.
  • Editing Audio beyond 25fps. Dialogue editing.
    Posted by Alister Robbie on November 23, 2005 at 12:37 am
    I am currently doing a lot (and I really mean a lot) of dialogue editing. It is the usual scenario of wading through interviews where the interviewee seems incapable of starting or finishing a sentence in the one breath. This means I am left to try and grab useable statements out of a rambling monologue by removing the “buts” and the “and_then” etc. Most of the time I can get this happening by cutting on right frame, but everynow and then, the limitation of working in 25fps means that there is a little click or “t” or “p” sound at the start or end of a clip.
    I remember when FCP was first released, one of the big claims was that FCP was able to edit audio down to 1/100th of a sec. Is it actually practically possible to do this? (or is it marketing BS?) I have had a look, and it appears that I can only keyframe audio down to 1/25th of a second (based on a 25fps timeline.)
    Any advice would be greatly appreciated.
    Cheers
    Al
    Alister Robbie replied 20 years, 10 months ago 4 Members · 5 Replies
  • Bouncing Account needs new email address
    November 23, 2005 at 3:50 am
    To access Sub-Frame Audio in FCP
    Click audio into Viewer, then:
    1. Magnify Glass (Zoom) Tool-Click Upscale (Frame shows as Large Grey Area)
    2. Arrow Tool-Click on FRAME in question.
    3. Option-Click to add key-nodes at sub-frame level (1/100th frame.)
    4. Arrow Tool-Click/Drag node levels.
  • Martin Baker
    November 23, 2005 at 10:44 am
    You can keyframe audio levels and pan to 1/100th second and you can slip an audio clip to the same accuracy but you can only create cuts at the frame level.
    Martin
    Digital Heaven, London UK
    ________________________________________
    NEW! MovieLogger – QuickTime logging made simple
  • Alister Robbie
    November 23, 2005 at 12:16 pm
    Matte,
    Thanks so much. Love your work. Very very cool.
    Al
  • Nick Meyers
    November 24, 2005 at 8:58 pm
    i do a lot of dialogue finessing, too, cutting out and’s but’s etc.
    simplest thing for me is to set my default audio transition to 1 or 2 frames.
    if i get a tiny click on the cut, then the tiny disolve fixes it.
    i’ve yet to resort to FCPs difficult subframe “editing”
    to set default:
    go to effects bin, audio transitions.
    type in new duration,
    control or right click on trans,
    “Set default”
    to add trans:
    control or right click on cut,
    add transition
    or
    select cut,
    Option Apple T
    cheers,
    nick
  • Alister Robbie
    November 25, 2005 at 12:17 am
    Hi Nick,
    Thanks for the tip. I have been working with short audio transitions to get the clicks, but I prefer keyframing as a method so that the clip is clean on its own. At this stage of the edit, we are doing a lot of shuffling, so I am trying to avoid using transitions so that it is easier to move things around.
    BTW, the sub-frame editing is just unreal. It has been working a treat and is really easy to get to.
    Cheers
    Alister
